Results 1 to 10 of 14
Thread: drill bit sharpener
    Aaron
    In the Mountains
    Default drill bit sharpener
    these probably 50 bloody bits sitting on my bench and they are all fooked. well, blunt as can be anyway.
    any recommended sharpeners for drill bits? dont want to pay a shit load for one, can i get one that works?
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    do them yourself??? on bench grinder
    Aaron
    In the Mountains
    i suck and have trouble getting the angles right
    Senior Member Casey-G's Avatar
    Casey
    agree with lolwat;
    get a linisher belt, watch some youtube vids... practice
    Profit
    Michael
    Crimebrook 2749
    youtube links and make your self a guage(get angle from google) make out of metal plate and use that as a guide for the angle (get the angle right and twist it as you go over the wheel)
    Casey
    Just get two hex nuts M12 should be big enough, hole them together on a flat edge n match you bit against that.
    Casey
    (flat edge being a flat side on either nut)
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Quick little howto for you.
    Dec 2010
    Cal
    ive done it with a 6 onch grinder,bench grinder, linsher and disk sander and we also have a drill sharpener at work it spins on a handle then goes in and out to suit drill.
    Glenn ke_70's Avatar
    Clay
    Barossa!
    we have one at home. i havent used it yet but its awesome to not pick up a drill that my retarted brother has ground off centre.
    get them from usa ebay. at least half the price. you need a transfromer though...
  1. Anyone have a 9mm drill bit, and a 10x1.25 tap?
    By Gunner in forum Sydney & NSW Events and Discussion
    Last Post: 9th July 2012, 01:20 PM
  2. Pedal Box Holes. Where to drill?
    By ke70 xx in forum Adelaide & SA Events and Discussion
    Last Post: 1st July 2009, 07:11 PM
  3. Left Handed(Reverse) drill bit
    By Jase86 in forum Tool Talk
    Last Post: 5th April 2009, 12:07 PM
  4. spot weld drill
    By johnk84 in forum Technical - Questions
    Last Post: 24th March 2006, 10:16 PM
