Page 7 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 61 to 70 of 195
Thread: Project Spirit
  1. #61
    Veteran 70rolla's Avatar
    May 2010
    Tyler
    Sutherland Shire
    how much to make up one of those coil brackets can you run it like that on a stock bigport pm me if you want
  2. #62
    Senior Member Casey-G's Avatar
    Casey
    I doubt you'll be able to run in on a stock 4a ignition system, unless you work around it with an external ignition module or something silly.
    I really don't have the time to be building other people shit just yet, however if i upgrade at any stage with anything, parts will be available for purchase
    Tires are only 195's atm on the g5's which i think are 7" wide... but the f series diff will open up a new world of cheap rims and such.
    got a few more updates ill post up later tonight
  3. #63
    Casey
    started the intercooler mounts/brackets tonight:
    then i ran out of gas for the heater in the shed... so i called it a night
  4. #64
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    you going to have a bar or anything infront of that intercooler??
  5. #65
    Casey
    The skirting thing that goes around the bottom.. ill have to cut parts of it out to fit it around the cooler however.
  6. #66
    May 2010
    On the F series, what will you ditch the drums for?
  7. #67
    Casey
    I might actually keep the drums, until i get a full hydro handbrake.
    Le'Updateo
    hatech arrived:
    and installed:
    Header flange has been made (took fo'eva)
    My soon to be runners compared to my cusco powerball headers:
    That is all
  8. #68
    Veteran Jdm-Mcc's Avatar
    Jake
    Wagga Wagga
    This will be wild!
  9. #69
    Michael
    Crimebrook 2749
    i have no way of putting my emotions into words about last couple updates
  10. #70
    Casey
    "POS That isn't finished" fit the description?
    Fiddled around with a bit of wiring tonight, got the injectors fitted off, TPS, CAS and the 4bar map sensor also Got the coils, Air and water temp sensors to go, then Main power to the starter and a few other lil bits n its all done wiring wise B)
    Also kinda half got the front end partially together to see what will need bracing ect..
    RE: manifold
    I have been doing quite a bit of reading ect of late in preparation of this manifold, obviously not intending to stay mainstream i have canned a "regular" type manifold such as you see with most custom set ups and have gone for a more "out there" style, aiming for very high flow and hopefully allowing some bigger numbers to be made.
    These are a few taken from turbosmart that are sorta like what im aiming for:
    you kinda get the idea
  1. Spirit wing
    By sleeper_13 in forum Cars or Parts Wanted
    Last Post: 14th March 2012, 09:41 PM
  2. spirit wing
    By fatke in forum Cars or Parts Wanted
    Last Post: 15th December 2010, 07:28 PM
  3. spirit wing
    By jmorley in forum Cars or Parts Wanted
    Last Post: 25th August 2010, 12:21 AM
  4. Parting out: Silvertop 20V AE71 Spirit project - Pics added
    By beerhead in forum Car Parts For Sale
    Last Post: 31st July 2007, 03:50 AM
