Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 47
Thread: toyota
  1. #21
    Senior Member doony's Avatar
    Dan
    sits like 80mm off the ground
    probably like 40-50mm from the middle muffler..
    apprz -2 camber rear left
    and -1 on rear right(drivers side) slight rubbing on the drivers rear.
    might run 10mm spacers up front too.
    need a wheel allignment
    Or driving in a wolf pack.
  2. #22
    Klutch
    eh, could be lower
  3. #23
    those have IRS?
    Either way thats fucken hot, and the wheels are porn!
    <img src=http://img114.imageshack.us/img114/3193/p1020339jk4.jpg border=0 alt= />
    Anyone get the License plate of that B& Hammer?
  4. #24
    Senior Member crackett's Avatar
    Needs the wheels off xsoarerx's car. Trick it out, they are hot as.
    Thought about a 1ggte or 1j conversion instead?
  5. #25
    Dan
    yeah i might be going 1j due to money factor, and its a bit easier to put in than 1uzfe.
    yes it has rear irs hense the natural neg camber with lower centre of gravity, only cut off like 2.5 coils off rear and 2 and a bit of the front.
    the rears were the worst, really big thick fucking things.
    took like 5minutes to grind em apart too.
    what are the wheels of xsoarerx's ? car ?
    specs ?
  6. #26
    15x8.5 and 15x11 neg offset SSR MKI's I believe, would look farkin' awesome on this.
  7. #27
    Dan
    will never fit
    well it would but would need serious work, which i dont really want
    but fuck
    cream over those specs!!!!!
  8. #28
    Veteran Konakid's Avatar
    Henry
    Eastern
    winwinwin
  9. #29
    Veteran svenmate's Avatar
    Svenbot
    East
    bosospec 1j would be sick
    cheaper too
    PM 'ae71' on here
    AE71 Build Thread
  10. #30
    Klutch
    You have seen the light.
  1. MRT review Toyota 86 vs Scion FRS vs Toyota 86
    Last Post: 2nd December 2012, 08:19 PM
  2. Toyota motorsports NZ - Toyota 86 Build
    Last Post: 13th October 2012, 01:21 PM
  3. Toyota 86 vs Toyota ae86
    By cswan in forum Toyotas in the Media
    Last Post: 6th August 2012, 03:16 PM
  4. Replies: 1
    Last Post: 27th September 2011, 07:05 AM
