swaps for my car?
Now i got ya attention we are willing to swap the ae86 for either of the following 9 thousand ono or straight swap for fc3s rx7 series 4 , 5 must have coilovers and be registered.
The Ae86 Has SA reg for 3 months and cannot supply road worthy as the conversion has not been engineered. Needs a few relays added to the Headlight and Indicator loom which are supplied with the sale.
No dash installed At the moment but is supplied .
Colour - Organic Orange Resprayed a Year Ago
Engine- SR20DET RED Top 174.4 RWKW on 13psi tuned
Gk tech RAS Kit
All EGR gear has been removed
Custom Engine Mounts
Low K's import engine
blitz sus power pod filter with alloy hard pipe
turbo smart t-piece boost controller
turbo smart blue silicone vacuum lines
Oil catch can
PLMS loom
Included with engine is a Z32 air flow meter with plug.
Custom Removable Rad Support
Fuel system - Custom Surge Tank
- VL turbo Lift Pump
- Bosch 044 feed pump External
- Custom enclosure on hinges
DriveLine- 180sx type x gear box
Uras Urethane Gearbox Mount
Nismo ceramic clutch
Nismo Lightened Flywheel
Custom one piece tail shaft
T-18 Diff with 3:9 locker ( come with extra 3 axels as spares)
Brakes- Front s13 sr20det calipers and discs
With EBC green stuff brake pads
Rear RA60 drums fully rebuilt
Cooling - ad rad intercooler with custom stainless piping
cooling pro silicone joiners
cooling pro alloy radiator
12" thermo fan
Suspension- BC coilovers 8kg s13 fronts and Ae86 rear 6 kg
Modified S13 knuckles
S13 lower control Arms
Ra60 Rack Ends
Series 3 Bluebird tie rod Ends
Modified LJ torana Castor Rods
Modified ae86 front swaybar
All urethane Bushes
JJR 4 Link Rose jointed Adjsutable arms
White-Line AE86 Adjustable Panhard Bar
White-Line AE86 19 mm Rear Sway Bar
TNB Front Strut Tower bar
Exhaust - Modified jjr Stainless steel dump pipe
3 "inch " custom mild steel exhaust
Supercat muffler with Custom Tip
Rims - Rears challengers 15 x8 -10 offset all new tires
Fronts Superlights 15x8 -4 offset all new tires
Wheel worx 27 mm spacers on Rear
Comes with 8 spare tires
Cage- 5 Point 21 safety cage
A spec harness Bar
Interior - 2 fixed back VELO racing seats
Elevo 90 mm dishes steering wheel
Turbo smart boost gauge
Autometer carbon series oil pressure gauge ( mechanical)
HPVA Tacho Digital (10 thousand rev limit reading )
HPVA Air Fuel Ratio Gauge
Battery cut off Switch
Dry Cell battery
Budget Temp Gauge (mechanical)
Aero - Tinted Windows
Bonnet Pins
TRD Copy Flares
Origin Sideskirts
Front Bar and Rear Bar Standard
If Anyone is interested in buying or doing the swap please leave me a pm on this thread or ring Ryan on 0433887627
Located in melbourne victoria
pm sent
Now parting out because of lack of interest.
shell - Organic Orange Resprayed a Year Ago shell with flares
$3000
Gk tech RAS Kit with plms loom to suit any car $3000
Custom Engine Mounts $150
blitz sus power pod filter with alloy hard pipe $150
turbo smart t-piece boost controller $40
Oil catch can $40
Z32 air flow meter with plug. $300
Fuel system - Custom Surge Tank $100
- VL turbo Lift Pump $50
- Bosch 044 feed pump External $150
DriveLine- 180sx type x gear box $600
Uras Urethane Gearbox Mount $100
Nismo ceramic clutch $200
Nismo Lightened Flywheel $100
Custom one piece tail shaft $200
offers
With EBC green stuff brake pads $250
Cooling - ad rad intercooler with custom stainless piping $500
cooling pro alloy radiator $200
12" thermo fan $30
Suspension- BC coilovers 8kg s13 fronts and Ae86 rear 6 kg $900
Modified S13 knuckles $200
S13 lower control Arms $150
Ra60 Rack Ends and 86 rack $150
Series 3 Bluebird tie rod Ends $40
Modified LJ torana Castor Rods $100
Modified ae86 front swaybar $30
All urethane Bushes
JJR 4 Link Rose jointed Adjsutable arms $200
White-Line AE86 Adjustable Panhard Bar $130
White-Line AE86 19 mm Rear Sway Bar $130
TNB Front Strut Tower bar $100
Supercat muffler with Custom Tip $200
Rims - Rears challengers 15 x8 -10 offset all new tires $400
Fronts Superlights 15x8 -4 offset all new tires $400
Wheel worx 27 mm spacers on Rear $80
misc tyres from $20 195 50 15 and 185 55 15
Cage- 5 Point 21 safety cage $400
A spec harness Bar $150
Interior
Turbo smart boost gauge $30
Autometer carbon series oil pressure gauge ( mechanical) $80
HPVA Tacho Digital (10 thousand rev limit reading ) $30
HPVA Air Fuel Ratio Gauge $30
Battery cut off Switch $10
Budget Temp Gauge (mechanical) $10
Aero
Front Bar and Rear Bar Standard $100 ea
Or buy the whole lot for 7700
