use a mig i can do it for u if ur in melbourne
hi all, i have a ra65 diff from the wreckers that i plan to weld up tomora for my corona, just wondering what type of welding rod would be the best to use? stainless?? thanks
cancling your subscription as a humanoid
dont need to use mig especially for the corona diff, i use 'weldall' by cigweld around all the important bits... very very strong, and then just fill with gp rods.
unless that corona diff is IRS, but the borgie ones have a closed center and a few bits breaking off doesnt matter.
thanks for the offer mate but im up in central qld out in bumfuck nowhere hahaha was just gonna use dads stick
yeah its irs, and im pritty sure i have some weldall in the shed
I've had a diff lock up on me while driving down the road at 40 mph from "slag" breaking off and getting between the gears. I'd be very clean and be sure to knock off all the loose slag IMO.
diff wont lock up on you from slag or spatter, you would of had a whole cold weld or something like that break off.
my first time welding a corolla diff i welded plates over the holes to stop slag and other material come out, but little did i know the forces at work, the plate broke off blowing a hole in the back of the cover plate and getting munched up on the gears, when i got round to inspecting, all that came out was this metallic goo and, to my amazement, no plate... it had magically vanished.
3mm plate btw.
yeah i spent ages chipping the splatter off and some serious time in the parts washer to get as much outa the case as i could, i just took it for a lap around the block and it was making all sorts of noises........... but turns out that i didnt do the center bearing support up properly was almost ready to cry hahah, so hopefully thats the only drama that i have, might even get real keen and drop the oil again to flush any other nasties out
i find that with every diff i have ever welded it will make alot of noise after, no matter how neat the job is. i can only speculate as to why... either way, there is alot of stress on there and i would expect as much.
