Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 11 to 20 of 110
Thread: Beams KE10 Build
  1. #11
    Senior Member Jordain's Avatar
    Jul 2010
    Jordain
    Penrith
    Parts room haha - Yes those are brand new KE10 Tail lights!
    Ke70 cut down cross member with stock Ke70 LCA with Ke70 struts with Ke10 top hat.. works nicely although RCA's and Custom Adjustable LCAs that are shorter are needed, so are camber top hats.
    14x8 -15 SSR Meshies.. Look nice as and suit the car perfectly!
  2. #12
    May 2011
    Ed
    Wynyard
    love this, how is the rack an pinion conversion working out?
    keen to do teh same thing to my ke18 panelvan
    don't suppose you have a spare front bar you want to sell by chance??
  3. #13
    Jul 2010
    Jordain
    Penrith
    I've actually just payed for a 3SGE BEAMS motor for the car. Rack and pinion works well. I do have a few front bars. I want $300 for a mint one or I got bent rusty ones you can have for $200 but theres a few people who said they want it but haven't paid yet so yeah.. might not have anymore. Also do you know Jono in Tassy... his got a ke10 !
  4. #14
    Jul 2010
    Jordain
    Penrith
    Saab Interceptors to be widened to 8" next week
    Nice fat 205/65's
    I get my 3SGE BEAMS this weekend hopefully. I picked up the Nissan S13 gear a few hours ago and plan to bolt it all in tomorrow morning on my custom LCA's... Need to cut the Spring perch off the nissan struts and modify them abit
    I'm not actually sure if I'm going to use the Nissan stuff. I need to do some measurements first, make sure it works.
    Either way I have to:
    -Shorten the LCA
    -HSD Coil over sleeve kit
    Ke70:
    Pros:
    -Bolts in
    -Its all standard
    -No steering geometry issues
    Cons:
    -4x114.3
    -Brakes are small
    S13:
    Pros:
    -Adjustable camber
    -Brakes are sorted out
    Cons:
    -4x114.3
    How i'm going to overcome my 4x114.3 stud pattern issue for a while... I got a set of SAAB 900 1985-86 4x114.3 chasers, same as the Saab 4x108 chasers on the rear just different stud pattern so that fixes the wheels problem for a little bit. I will end up changing all the brakes later on me thinks D:
    Low much?
    RRRRMMMM
    I really like these rims haha!
    The Camber is adjustable, the spring height is adjustable, the lock is amazing and the ackerman angles are very very close to original KE10 spec. But honestly, who knows if it works until you try it. By moving the wheel up and down on the shock I've noted that theres virtually any bump steer which is a good sign.
    But in all seriousness... it looks rediculous.
    At the moment I'm stuck, don't have any 4x114.3 rims so the car has to sit on space savers
    Shot of the Diff setup. I still got some work to do on the rear end but it is substantially easier than the front part of the car.
    If i haven't mentioned... I'm putting a 3s Beams motor into the car. It's going to be sick
    Any day now the halfcut should turn up
  5. #15
    Veteran shift_rook's Avatar
    SE Burbs
    what an epic thread, nice work, good to see you getting your hands dirty, kep the updates coming!
  6. #16
    Jul 2010
    Jordain
    Penrith
    Some JDM love yo!
    ah the Saab chasers fit so nice with the nissan suspension in the front. Get my HSD sleeve kit soon... then I can actually set it at a proper ride height!
  7. #17
    Stern but now fucked off...
    May 2005
    Nick
    Bloody hell, nice work. Can't believe I hadn't spotted this thread until now!
    I have a soft spot for KE10s...
    Though you should be slapped in the back of the head for putting an illest sticker on a KE10... lol
    Nice build thread.
    Can't wait to see the progress
  8. #18
    Jul 2010
    Jordain
    Penrith
    it's happened!
    Thanks Nicko, Hahahahah... I love being a tosser with all these random JDM stickers, It annoys the shit out of all my mates.
    going to take abit to get her in... drop the cross member... place the engine on the cross member then shape a firewall around it!
  9. #19
    May 2005
    Nick
    Beams + KE10 = FULL OF WIN !
  10. #20
    Jul 2010
    Jordain
    Penrith
    It will be quick, well balanced and hopefully should steer, point and feel the same as my gearbox superkart
  1. JDM BEAMS Notchback track build
    By ke_70 in forum AE86 Owners Forums
    Last Post: 19th May 2014, 11:55 AM
  2. Outlaw Ke10 Build.
    By Jono.C in forum Other Toyotas
    Last Post: 2nd March 2012, 06:41 PM
  3. Replies: 12
    Last Post: 29th November 2010, 09:00 AM
  4. Ke10 build
    By Jordain in forum Other Toyotas
    Last Post: 9th August 2010, 07:46 PM
  5. WTB ke10
    By zookieboi in forum Cars or Parts Wanted
    Last Post: 4th July 2009, 08:58 AM
