Page 3 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 21 to 30 of 110
Thread: Beams KE10 Build
  1. #21
    Aug 2010
    Adrian
    South
    you will be driving it from the back seat, by the looks of it
  2. #22
    Senior Member Jordain's Avatar
    Jul 2010
    Jordain
    Penrith
    Dreaming hahaha!!
    More pictures of the motor in the car... Its a challenge to get it in...
    quoted from my facebook: " Cut the shit out of the car, take the crossmember out, then lift the body to the roof then push the motor under it then lower the body then use the engine crane to lift the engine up then put the crossmember in and bolt it in. "
    Seventy, it's not to bad hey.... Motor is far back but the seats aren't to far back but won't be fitting an adult in the behind the passenger seat because I plan for floor pedals so seat is far back anyway!
  3. #23
    Jul 2010
    Jordain
    Penrith
    Oh also I have to cut all the trans tunnel out and redo it all again -_-. Tomorrows job is to get the motor in there with the engine mounts all welded 100% with the gearbox mount all welded in. I want it sitting in there.. then once thats all done I will bolt the gearbox mount in without the gearbox/engine and cut the tunnel out and recreate a tunnel 400 wide to comfortable fit the 6 speed box in. It will be big in the KE since its so little. Once thats done, start the firewall boxing.
  4. #24
    Jul 2010
    Jordain
    Penrith
    Shortened cross member for KE10
    Sitting in its new home
    Should be able to fit a decent exhaust into it!
    Sumps abit of a worry but hopefully it won't get ripped off.
    Mounts have been made but first half of the day went to cutting more of the firewall out because it just wasn't sitting right and the firewall was rooted anyway so might as well start over. Somebody added a brake booster in about 1990..... and they just hacked and stick welded it in.
  5. #25
    Stern but now fucked off...
    May 2005
    Nick
    Epic amounts of win in this thread
  6. #26
    Jul 2010
    Jordain
    Penrith
    current plans are to lower the crossmember 40mm, gives me more room in the engine bay, allows me to get the rear coil pack and allows room for a strut brace. Lowering the crossmember would typically make it handle like poo but since I'm start from scratch with the suspension it doesn't matter!
    More pictures soon.. I hope to atleast have it mounted by tonight, but I think I'm dreaming hahahah!
  7. #27
    May 2005
    Nick
    At the progress you're making on this thing, you should stop fucking about and just dry sump the fucker...
  8. #28
    Jul 2010
    Jordain
    Penrith
    Space the crossmember down
    Engine sits further back and lower too!
    Holden Astra radiator
    Haha I don't have the dosh to drysump it or even put ITB's on it. I was going to buy a set but changed my mind when I worked out a realistic price of what it will cost to finish it off so the plan is to finish it off, then once I've recovered from the intial hit I will build the motor up...
  9. #29
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    ooobecuase beams in a ke10 wont be fast enough HAHHAHA
    fucking tidy car, looks like you got room for a 180 project there
  10. #30
    Jul 2010
    Jordain
    Penrith
    Hahahah I still think it will be abit slow
    Yeah plenty of room for a 180 project.... but who wants it hahaha!
  1. JDM BEAMS Notchback track build
    By ke_70 in forum AE86 Owners Forums
    Last Post: 19th May 2014, 11:55 AM
  2. Outlaw Ke10 Build.
    By Jono.C in forum Other Toyotas
    Last Post: 2nd March 2012, 06:41 PM
  3. Replies: 12
    Last Post: 29th November 2010, 09:00 AM
  4. Ke10 build
    By Jordain in forum Other Toyotas
    Last Post: 9th August 2010, 07:46 PM
  5. WTB ke10
    By zookieboi in forum Cars or Parts Wanted
    Last Post: 4th July 2009, 08:58 AM
