Cusco tops
Ke30 radius rods and brackets
Cool little capella that I fell inlove with...
well come a long way.
KE20 crossmember, all standard but I unpicked the mounts and moved them out 15mm to line up perfectly. Here's a picture of what I mean.
Then mig welded the mounts and put a few plug welds... that's not moving anywhere anytime soon.
This shows the 30mm crossmember space down ... no I won't be using oversized nuts lol. Hopefully have the 30x40mm solid bar made by this afternoon.
This picture show's how far back the engine is, I've got a few solutions to the coilpack problem.
With a 40mm RCA, Cold bent strut to re-allign the King Pin Angle. As you can't see, theres about 30mm from the 7" rim to the strut and thats all square... so I'm going to get abit more camber from the strut. Also show's how low the motor is, it's a lot lower then a 4k in a KE10, although it's not lower than the sill's.. Plan is to make a 12mm Bash plate that goes from the front of the car to the crossmember to protect the nice beams sump...
Nice fit so far... very happy with it.
Decent amount of lock, with a 195/45r14 tyre, abit of massaging on the inner guard and some more castor I'll be able to get a lot more lock. although may need the front of the guard choppped out to get lock... decisions decisions.
