Page 8 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 71 to 80 of 110
Thread: Beams KE10 Build
  1. #71
    Senior Member Jordain's Avatar
    Jul 2010
    Jordain
    Penrith
    I totally agree. I thought I would have had to Machine the rack down at atleast within 5mm of the LCA bush.... it's no where near parallel to the tie rod end. The tie rods don't even sit parallel to the rack.
    The rack is exactly 85mm from the centre of the centre of the LCA bushings. NOTE: I had a AE86 crossmember in my garage, and these had the rack about 115mm behind, not 85mm. I chose 85mm for a few reasons, one being it suited what I wanted for ackerman better, and secondly the KE20 steering knuckles (108mm modified) are considerably shorter than AE86 (132.5mm) and AE86 p/s ones (115, 120mmish- can't remember exactly. Also, this way it doesn't put too much strain on the KE20 knuckles and rack ends when turning with lots of lock.
    The Rack is 6mm ABOVE the LCA inner pivot point. Saying that another way is the centre of the rack ends are 6mm higher from the ground than the centre of the LCA inner pivot points.
    AE86 racks are 7mm higher. So very similar. In my 1/2 scale drawings, this measurement seemed to make the biggest difference to any bump steer.
    Quote from Rob ( Successful KE20 R&P conversion )
    "Did 2 attempts. first one I shortened the rack by how much closer the LCA inner pivot points are in my design, but it didn't work. A lot of bump steer, possibly more than a standard AE86. But it was toe in on compression, not toe out. Yuck.
    Fitted a spare rack bar I had (standard length) and brilliant! No bumpsteer at all in compression and the in the first 25mm of droop. Then slight toe out with more droop. "
    NOTE: Without the 40mm RCA's it would still have no bump steer in compression at all, nor at least for the first 65mm in droop. But this isn't much good for roll centres, and understeer would result in hard cornering (due to tire scrub, not bump steer obviously). Besides, a bit of extra ackerman on the inside wheel in turns never hurt... check out the competitive IP cars like the front line escorts
    It does have 0 bump steer. It does need a 40mm RCA though and I need to wind more camber in by making a set of custom struts.... Have to remove the Cast hub with stub and reset the strut tube with more King pin inclination angle............
  2. #72
    Jul 2010
    Jordain
    Penrith
    Here's an update...........
    Recieved my $95 Delivered Alloy radiator
    Cooked a Beams rocker cover...
    Nah jokes just preheated it to about 50c then gave it a coat of wrinkly paint
    Made a tab for the radiator.. yes it will be rubber mounted.
    Chopped more of my car out :bash:
    Worked from 5pm to 1:30am this morning making that one part.... and did a few other things.
    Tacked in the drivers side
    Welded it in.
    Tadaaaa. I'm not sure if I like it or not. it looks to boxy/flat :fuzz:
    Update later tonight :laff:
  3. #73
    Apr 2010
    Mike
    put some "speedholes" in there
  4. #74
    Jul 2010
    moron
    Speedholes ey? What keeps doin' that!
  5. #75
    Aug 2010
    Adrian
    South
    Not sure which side the oil filter is on, but you might need holes in for oil cooler lines
  6. #76
    Jul 2010
    Jordain
    Penrith
    Oil filters on Passanger side. That's a good idea. I'm sure I will Fill it up... Might make a nice alloy overflow bottle, oilcooler out the front etc.... sort something out anyway!
  7. #77
    Glenn
    North Ringwood
    so how did you go machining out the black top throttles to get 49mm butterfly.. and how did your inlet go that you made up ,was reading what you said to a guy on rolla mods,that was going to do a carby version of the beams
  8. #78
    Jul 2010
    Jordain
    Penrith
    Sold a KE10 to Luke
    Sold an Ma61 to a fellow Ae86dc drift nut haha!
    The car at its set ride height...
    slight poke in the front end department
    purchased a cheaper alternative to quads than Celica_Ra45's nice cast TRD copys.
  9. #79
    Jul 2010
    Jordain
    Penrith
    Not to much updates.... just waiting for my mate to finish building an rx3 so he can start working on my firewall as i'm to scared to touch it!!
    I'm doing Mechanical Engineering!
    Pedal box.
    LEEN J160 shifter relocation kit
    Sleeping in the shed
    Set of 14x7j +13 reversies popped up so grabbed those and also grabbed a 'special' girlfriend haha
    Then a set of 14x7 0 and 14x6.5 +10 popped up so thought i'd grab those last night too...
    quick test fit
    chucked a 165/55r14 on the front and a Falken 195/45r14 on the rear
    Sat in garage for about an hour....... thinking about how i'm going to get rx7 AJPS brake kit under them NEK MINNIT.... decided the front wheels need new inner barrels made up without the SSR buldge.
  10. #80
    Jul 2010
    Jordain
    Penrith
  1. JDM BEAMS Notchback track build
    By ke_70 in forum AE86 Owners Forums
    Last Post: 19th May 2014, 11:55 AM
  2. Outlaw Ke10 Build.
    By Jono.C in forum Other Toyotas
    Last Post: 2nd March 2012, 06:41 PM
  3. Replies: 12
    Last Post: 29th November 2010, 09:00 AM
  4. Ke10 build
    By Jordain in forum Other Toyotas
    Last Post: 9th August 2010, 07:46 PM
  5. WTB ke10
    By zookieboi in forum Cars or Parts Wanted
    Last Post: 4th July 2009, 08:58 AM
