Will part if enough interest.
Diff = $1500
Everything esle = 3000
just a note the tail shaft suits F,E and T series
Hey everyone. In my car atm i have a modified ca18det. I am looking to go in a different direction with my car and im posting up a EOI on the whole bolt in package.In this setup i was looking for a more responsive power. Here are some specs on everything forsale.
Engine.
Rebuilt CA18det. New bigends and main bearings. Linished and crack tested crank. Brand new NA pistons installed for a responsive setup. 1.2mm metal head gasket. ARP2000 head studs. Gates timing belt. Aftermarket low mount turbo manifold. t25 turbo. Custom oil return from back of head to sump. Braided turbo lines.
Gearbox.
standered 5 speed with standered flywheel and a heavy duty clutch.
Exhaust.
have a normal dump pipe or a screamer. 3inch exhaust through. high flow cat and a xforce muffler.
Diff.
A targo yr22 F series with a 4.3 locked center. mounts converted to bolt into either ae86/ae71 or ke70. ( All work was done by difftechics )
Conversion.
custom engine mounts, custom gearbox mount and a 1 piece tailshaft. ( tailshaft made by truckline )
Other.
modified engine loom to suit ae86 harness. Intercooler and piping to suit conversion. Vr holden airbox modified to suit. chipped ecu. have other chips with difernent map tunes if you decide to want more power.
I think that is about it. if there is anything else i will be sure to update the thread. As title says this is just a EOI. I would be looking for $4600 or close to for the whole lot.
Contact: Nick 0413836004
SOLD!!!!!!!!!!
Diff = $1500
if my engine setup sells i may be interested in everything except the diff
No worries. dont sit to tight. let me kno. im very suprised how much interest this package has on boostloosing. got a guy coming to look at the whole lot tomoro.
will bump. asap with out come
Deposit taken. Package sold.
close thread
