Results 1 to 10 of 12
Thread: ae86 rally incar
    Mar 2011
    Mike
    Warrandyte
    Default ae86 rally incar
    Hi there,
    Here is some incar footage from a rally we did
    Redtop smallport 4aege
    Veteran slide86's Avatar
    Huw
    Hills
    amazing work mate.
    got any info on the car or a build thread?
    Mar 2011
    Mike
    Warrandyte
    Thanks mate...
    here is some info (copied from the guy who I bought the car off)
    ENGINE :
    Head - redtop smallport, Toyota echoe buckets/shims, TRD valve springs, Kelford cams, adjustable cam wheels, TRD 0.8mm stainless head gasket, Injectors are Mazda 323 BFMR 1600cc Turbo
    Manifolfd - Technotoytuning(USA) manufactured, c&c machined out of block alloy
    Air Filter - Pipercross
    Bottom end - ARP Rod bolts. pistons, rods and crank all standard
    Other - front mounted oil cooler and remote oil filter, electric fan, both rocker covers are breathable
    TRANSMISSION :
    T - 50 5 speed with 1st - 3rd gear close ratio kit
    Twin plate brass button clutch
    DIFF :
    5 link, Housing is AE86, LSD unit has been fitted to Toyota Town Ace 4wd van head, ratio is 5.1:1 and crown wheel is 7inch.
    Diff has been moved back 30mm so driveshaft has no chance of bottoming out in gearbox, and improves wheelbase and handling.
    Links have been made adjustable and rose jointed at one end with nolathane bushes at other.rose joints chromolly.
    SUSPENSION :
    Front - AE86 struts with 40mm bilstein inserts, height adjustable, 150kg king springs, Tein adjustable camber strut top plates
    Rear - Bilsteins with standard springs removed and softer ones fitted
    STEERING :
    Quick rack, adjustable castor and rose jointed lower arms
    BRAKES :
    standard AE86 rotors and callipers,
    Wilwood bias valve
    Veteran timbo's Avatar
    Tim?
    Wild West
    very nice!
    Senior Member Dori_Dori's Avatar
    Andy
    Westside
    very nice work on your machine
    got any pics of the engine bay
    Cheers,
    Mar 2011
    Mike
    Warrandyte
    Here you go. It's a bit dirty but it is a rally car!
    Here is a video from the rally we did on the weekend - unbelievable roads!!!
    Andy
    Westside
    very nice keep up the good work
    Aaron
    In the Mountains
    anyone who is doing gravel rally in a 2wd car is fairly nuts IMO. nice work!
    Michael
    Jyväskylä
    Ouninpohja
    Finland
    2wd is the way of future! Bring on 2013!!
    Michael
    Jyväskylä
    Ouninpohja
    Finland
  1. IPRA NSW Wakefield park incar AE86
    By 3sglevin in forum Youtube Chan
    Last Post: 17th August 2012, 11:49 AM
  2. Replies: 7
    Last Post: 26th October 2011, 06:48 PM
  3. Mad incar....
    By ThatsHowWeRoll in forum Youtube Chan
    Last Post: 23rd March 2010, 02:04 PM
  4. High Revving 86 Incar rally action.
    By ae86trueno in forum Toyotas in the Media
    Last Post: 24th April 2008, 07:48 AM
  5. ae86 incar (and out of car) from winton raceway 20-06-06
    By devolutio in forum Toyotas in the Media
    Last Post: 26th July 2006, 01:50 PM
