Page 4 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 31 to 40 of 97
Thread: Hydraulic clutch release bearing for T50 gearbox
  1. #31
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    numbers??? like between xxx and xxx
  2. #32
    Jim
    Wodonga
    Finally got the release bearing Im after. You could use this straight out of the box, but I would recommend a spacer be made up to fit over the gearbox nose so the bearing is located concentrically
    The release bearing on the right. It slides over the gearbox nose, no bolts needed.
    The bearing sitting in place. you only need to replace one bolt with this locating pin. Pretty simple.
    Once I get this mounted and tested, I will post up some results
  3. #33
    Junior Member Phife's Avatar
    Col
    I've actually been looking at doing this setup as well since the JDM bell wasn't going to work for me.
    I already got the saab slave and bearing ordered from the UK, just need the adapter.
    Definately interested in both T50 and W box adapters if it happens.
  4. #34
    Jim
    Wodonga
    Thanks for the link Phife. The original set of images are actually of a SAAB slave. As you have worked out, they aren't cheap, and they need an adapter like the one I made. The last bearing I have pictured doesnt need an adapter, and it may be possible to fit onto a W series box, which was my initial intention. Its also considerably cheaper. I have about 4 of the SAAB bearings here, unfortunately they wont work with the W boxes.
  5. #35
    Jim
    Wodonga
    Had a quick read of the mondeo link Phife. I have a mondeo bearing here also. It obviously fits, however, it is a bit pricey compared to the SAAB unit and both need an adaptor. I dont particularly like the idea of bolting the adaptor to the modified input sleeve, as the surface of the sleeve is as cast and not perfectly true. The reason they did this though is because the mondeo bearing, (the one I have anyway), has the oil seal built in which wont fit the toyota shaft. So they used the original toyota seal, which is in the input sleeve.
    I would think it would be a better option to replace the entire input sleeve like I did with the SAAB unit on the mondeo unit. You have to machine a spacer anyway.
    The Howe racing unit which I have pictured is a much easier fit, heaps cheaper, and doesn't need any machining. Although I recommend a sleeve is made up to align the bearing perfectly on the input shaft sleeve in the interest of reliability.
  6. #36
    Jun 2011
    Gareth
    Katoomba
    Im putting a 4age with t50 into a ke10 corolla. The clutch slave hits the steering and a JDM bellhousing will just make it hit the same on the other side IMO.
    So im very interested to hear more about this conversion! I have sent you a PM Jimmy
  7. #37
    User fantapants's Avatar
    Pat
    if the clutch slave is in the way of steering, then it IS a jdm bell, no?
    06/07/2011
  8. #38
    Col
    I have the same problem, both ADM and JDM clutch slave locations affect steering lock in a KE10
  9. #39
    Pat
    ahh my bad.....
    06/07/2011
  10. #40
    Jun 2011
    Gareth
    Katoomba
    I was looking at the possibility of putting a 90 degree angle plate of the lower gearbox mounts and using a long pushrod on the slave until i found this thread.
  1. T50 release bearing noisy!!
    By bradae85 in forum Technical - Questions
    Last Post: 3rd August 2012, 08:17 PM
  2. Replies: 3
    Last Post: 19th May 2012, 03:34 PM
  3. 4age clutch release bearing
    By harvo in forum Car Parts For Sale
    Last Post: 30th April 2009, 01:30 PM
  4. hydraulic throw out bearing
    By 350hp4agte in forum Offtopic Discussions
    Last Post: 2nd April 2009, 08:02 PM
  5. T50 clutch fork and bearing carrier
    By terryo in forum Cars or Parts Wanted
    Last Post: 24th April 2007, 03:08 PM
