Page 7 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 61 to 70 of 97
Thread: Hydraulic clutch release bearing for T50 gearbox
  1. #61
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I had a thought that is probably what you already had on your mind- people are reporting this hoe unit is flogging out seals and is suffering from scored pistons. Now the only thing that can cause pistons to score is if they are rubbing hard against each other. This leads me to think that it's due to side loading, aka incorrect mounting just as you where alluring to. So if a proper part was made as you suggested then I don't think it would fail anymore.
  2. #62
    Jim
    Wodonga
    Thats exactly correct Sam. I dont want to bag a product unless I know for sure what the problem is. The Howe unit is a multifit unit which I am sure will work perfectly if mounted correctly. It is actually a well machined, nice looking unit. I did look into the quartermaster unit, that is a suggested replacement for the Howe unit in the states, but got no replies. It does look as thought the quartermaster unit mounts better also. To be completely honest, it will come down to price really, as both the SAAB and HOWE units look quite good.
    1) The SAAB unit is cheaper initially, but requires the adaptor. Only for T50
    2) The HOWE unit is more expensive, doesnt need an adaptor as advertised, but really needs an adaptor made for reliabiltiy
    3) Another bonus for the HOWE unit, is it will fit the T50 and W5x series boxes
  3. #63
    Senior Member Prime86's Avatar
    Sep 2009
    Brad
    Perth hills
    Hi Jimmy19650
    I just came across your thread and was intresting reading. I myself was looking at going down the path you are with this type of release bearing setup.
    I have read a thread on a guy who has done what you have done and he has it sorted although he had trouble also with the seal in the release bearing being damaged.
    This guy owns a full N2 racecar in NZ. He used an AP Racing setup at first with A Tilton pedal box arrangement. The AP Racing setup when hot he experienced clutch drag as the bearing started to fail (he rev's his engine to 10,000rpm) may have to do with vibration etc. I Believe that Titon themselves make a kit for the T50 gearbox as this is what he replaced it with. From what I could see the front seal carrier housing is different from your pics but im going to look further into it myself also and ask him where he sourced this kit.
    Here is a link to his build with this setup hope it helps in some way.
    Brad
  4. #64
    Jim
    Wodonga
    Thanks Brad. I've used the tilton units on a few race cars, and really, for the huge cost, they aren't hugely better than OEM SAAB, or even the LS1 unit. However, 10000rpm bearing speeds will definitely cause problems with all but the very best units. I am a bit surprised with the interest in this project, so I will put a bit of effort in to get it as reliable as possible, and finished asap. As I have said quite a few times, my aim is reliability and reasonable costs. i have tried at least 6 different bearings and variations, but I seem to always hover back to the SAAB unit for the T50, and the HOWE for the W5x series. Better stop typing and continue testing.
  5. #65
    Sep 2009
    Brad
    Perth hills
    No problems Jimmy. I would hate to think what the Tilton kit would cost. I thought maybe there was something you could see in the thread that could help since you have had experience with this type of system. Wasn't sure if it was an off the shelf item for a T50 or he had modified something to fit. Yeah 10,000 would cause alot of its own problems. Very intresting thread please keep up the good work and keep us informed with your findings.
  6. #66
    Jun 2011
    Gareth
    Katoomba
    Just thought i would check in to see how the SAAB adaptor is going? The motor (4age) will be going back in the car (ke10) in the next 2-3 weeks and im really hoping to avoid using the Tilton and HOWE units for issues around reliability and cost.
    Need a test pilot for a finished unit Jimmy? If theres no chance of things being ready in the next few weeks let us know and i will look more closely at HOWE and Tilton.
    Which HOWE bearing fits a T50, and which is recomended? i notice there is a few on the site, it looks like some float? seems dodgy
    Would i be right in saying 300 series tilton fits? Can anyone give information as to which Tilton bearing setup will fit the T50? Earls were not very helpful when i rung them.
  7. #67
    Jim
    Wodonga
    Ok, I have made a few of these now. I have one being tested by a member on his car, once I sort out any problems and make any mods, I will let you know.
  8. #68
    Sep 2009
    Brad
    Perth hills
    Looking forward to the results Jimmy, hope it works out well. Keep us informed of the progress and I mite hit you up for a kit if it all works out later...Lol.
  9. #69
    Jim
    Wodonga
    Finally finished this project. Made a few mods since last time. Only tested on standard type pressure plate though. All good.
    This picture shows the release bearing assembly fitted into the bellhousing. The hydraulic lines can either be routed through holes in the top of the bellhousing or through existing holes in the bellhousing.
    Here's a picture through the clutch fork opening showing the release bearing sitting against pressure plate (dust cover not in place)
  10. #70
    Sep 2009
    Brad
    Perth hills
    Hey Jimmy
    Looks good mate, nice job. What could we expect the cost of this unit to be?
    Brad
  1. T50 release bearing noisy!!
    By bradae85 in forum Technical - Questions
    Last Post: 3rd August 2012, 08:17 PM
  2. Replies: 3
    Last Post: 19th May 2012, 03:34 PM
  3. 4age clutch release bearing
    By harvo in forum Car Parts For Sale
    Last Post: 30th April 2009, 01:30 PM
  4. hydraulic throw out bearing
    By 350hp4agte in forum Offtopic Discussions
    Last Post: 2nd April 2009, 08:02 PM
  5. T50 clutch fork and bearing carrier
    By terryo in forum Cars or Parts Wanted
    Last Post: 24th April 2007, 03:08 PM
