would be interested in ae71 pedal assembly and all the stuff for 4a conversion into ke?
-PAIR 14x6.5 +10ish Arbun very good conditon, 80% 185/60 Falken Azenis - $180
-unknown brand stainless Japanese AE86 2.25" front-pipe and mid-pipe to diff, VERY good quality but missing springs - $180
-AE86 steering-rack, Super Pro rack bushes, AJPS lock-spacer, RA60 rack-ends - $200
-front brake set-up JDM AE86 calipers, Project Mu NR pads, slotted Dixcel rotors, AE86 backing plates - $450
-NEW OBP pull-type hydralic handbrake, 600mm vertical lever - $160ono
-T50 on AE71 crossmember, no bell-housing or shifter - $200ono
-TRD style adjustable cam sprockets - $140
-beige Bigport rocker-covers + coil-cover + oil-cap - $80
-4AC/GE sandwich plate for rubber hose oil-cooler - $10
-china pod filter - $10
-GReddy turbo timer - $40
-AE86 rear rotors, need machining - $50
-two pairs stock KE70 castor-rods and mounts. bushes are okay - $20
-52mm Omori oil press + oil temp gauges with all wiring and senders- $100 each
-20mm HKB steering wheel spacer w/ extended bolts - $20
-TE71 "quadlight" grille - $50
Located Ridgehaven, ADL.
Thanks, Ben.
have you got rcas ?
also what control arms do you have ?
pm me with prices
diff is tempting
pm'd
Yes, added.
shotgun drift button pm me bank details
TOM'S 350mm steering wheel + horn button, good cond
PICSS NOW
whens the spanners coming to this?
Ah, during the week.
Keeping Tom's wheel Marvis, sorry!
