Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: G series Diff info + Discussion
    Senior Member PRIMRK's Avatar
    Dec 2009
    Cameron
    Brighton
    Default G series Diff info + Discussion
    I couldn't find a much G series diff info on here to start with so I figured I'll throw this up for those like me that may be running a bit more power than most and want to bullet proof their car as much as possible.
    (if this has already been covered please let me know where to find it)
    Century:
    VG40:
    Solid Axle (coils) G392: 8.0", 3.15:1, 2 pinions, Open
    5x114.3 unknown Ventilated disc, 1 piston calipers
    Cressida:
    MX83:
    Double Wishbone G313: 8.0", 3.90:1, 2 pinions, Clutch LSD
    5x114.3 N/A Ventilated disc, 1 piston calipers
    Comments: Only Grande models have LSD.
    Double Wishbone G315: 8.0", 3.90:1, 4 pinions, Clutch LSD
    Crown:
    UZS131:
    Double Wishbone G314: 8.0", 3.90:1, 4 pinions, Open
    Double Wishbone G474: 8.0", 3.94:1, 4 pinions, Open
    Hiace:
    RH10:
    Solid Axle (leaf) G162: 8.0", 5.28:1, 2 pinions, Open
    5x114.3 unknown Drum
    YH50:
    5x114.3 1470mm Drum
    Hilux:
    RN20:
    Solid Axle (leaf) G142: 8.0", 4.87:1, 2 pinions, Open
    5x114.3 1375mm Drum
    RN40:
    5x114.3 1410mm Drum
    Soarer:
    MZ20:
    Double Wishbone G295: 8.0", 4.10:1, 4 pinions, Clutch LSD
    Supra:
    JZA70:
    Double Wishbone G299: 8.0", 4.10:1, 0 pinions, Torsen LSD
    Double Wishbone G319: 8.0", 3.90:1, 0 pinions, Torsen LSD
    MA70:
    Double Wishbone G305: 8.0", 3.72:1, 4 pinions, Clutch LSD
    I found all this info here:
    Dec 2009
    Cameron
    Brighton
    Any one know of an aftermarket 1.5/2 way LSD available for the G series?
    Senior Member ecko's Avatar
    Jack
    Blackmans Bay
    TRD PN 41301-MZ210
    ill get you a price mate
    Dec 2009
    Cameron
    Brighton
    thanks man
    Veteran Konakid's Avatar
    Henry
    Eastern
    To be honest, if you are running enough power to warrant any greater strength than an F series, you have the wrong motor in your corolla.
    Good to have an info thread for those with cressida's etc though.
    Dec 2009
    Cameron
    Brighton
    I could prob get away with an F series but want to have a rig that shouldn't fail, I'm using a V8 so unlike a lot of engines it will have torque and I may want to take it to the drags every now and then so when running slicks and having torques I want the stronger option.
    Granted yes there will be a minute amount of people who will need a G series diff but i chucked the info up there anyway.
    Jim
    Wodonga
    Yes, the g series is over engineered for a corolla, and quite heavy. However, you cant beat the availability of LSDs, ratios, brake options, wheel options and peace of mind. I have G series in 2 AE86s, and I know I will never have to worry.
    Dec 2009
    Cameron
    Brighton
    What are your G series out of and what brakes/lsd/ratios are you using?
    Jim
    Wodonga
    G series out of an RN27 hilux rear wheel drive, with an G series LSD. The diif I got had something like a 5.3 ratio, but I am using a 4.7 ratio at the moment. Use the rear discs out of an MA70 supra. There is quite a bit of info on this conversion available. You can simply oxy cut all the brakets etc off a a standard diff then re-weld, or have brackets laser cut if doing a few. I converted to coil overs on the rear so I didn't use the spring seats. If you do this you will need to reinforce the floor and mount the coil over unit to the diff in double shear. Using standard mounts on the floor and single shear mounts on the diff is probably ok, but dont know for how long. I will try to dig up some pics. I know i still have the welding jig for the diff.
    Just remember the G series is very heavy, and will probably upset the balance of the car unless you use a corresponding large engine/gearbox in the front. from memory, the g series diff added about 40kg to the weight of the car.
    Dec 2009
    Cameron
    Brighton
    ok well in my case of taking out a 4age and t50 and replacing with a 3uz and r145 i figure the balance will almost be back to the norm...but I've also got a 60lt fuel cell in the back too though...
    Any links i can chuck in the first post to a brake conversion page?
  1. F series Diff info + Discussion
    By Konakid in forum Technical - Articles
    Last Post: 6th July 2019, 01:34 PM
  2. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
