You'll need JDM calipers for both options, because they're to suit a GT-S corolla.
looking at buying BC coilovers then trying to work out brake options
any reccomend either of these?
then what else do i need after that, just some hubs and calipers? adm or jdm?
also, how much is postage, does it work out cheaper than buying some here?
also if you are looking at buying jdm callipers, why not think about a wilwood or rx7 setup?
Emailed them and awaiting a response on a price to Australia, shouldn't end up being more than $100
Slotted and drilled is a lot more than $100 from what I've seen, only expensive parts going to be Jdm calipers and it's less mucking around than an rx7 set up and don't have cash for wilwood.
drilled is something you dont want
try and get just slotted and not 88 rotors
