Page 1 of 29 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 288
Thread: OniKyan's Thread... Euro, BMW, JDM, Racing, Hip Hop, Random Jargon
    Senior Member OniKyan's Avatar
    Mar 2011
    Daniel
    Default OniKyan's Thread... Euro, BMW, JDM, Racing, Hip Hop, Random Jargon
    Not sure if I'm overstepping my welcome but here goes....
    Not dissimilar to Jake's thread, however, rather than just being random pictures of dope shit, try to keep this one on a theme. Web based magazine style articles and information, epic build threads, Speedhunters/Nori Yaro blog posts etc.
    I'd also rather not fill other peoples threads with my rambling about E30, E21 and 2002 nonsense.
    Random Ideas:
    Epic videos of epic cars, doing epic things.
    Build Threads that caught your eye as being, over the top, unique, extreme dedication to detail, etc.
    Gr. 5/GR. A/Group B/N2/N1/IPRA/Sports Sedans/D1 - etcetera related pictures/videos/articles
    Any grass Roots Motor sports
    Cafe Race
    Any other crazy, cool shit, you find that doesn't fit into other threads.
    Rules:
    Use proper grammar.
    Post dope shit.
    Embed YouTube videos. Don't post links, it looks messy - [youtube] video code [/ youtube] Minus spaces.
    If you're getting your flame on, do it in a constructive way. Don't be saying "That's gay, herp derp, derp". Give an actual reason as to why you don't like something, or what you may do differently given the opportunity.
    Formalities out the way, let's set this thing off. If you want.
    BMW M12/7
    Used in both Touring Cars (BMW 2002's, 320's - GS Tuning, Heidegger and others) as well as F2. Sixteen valve cylinder head, slide throttle fuel injection (Bosch/Kugelfischer). These engines have gear driven cams, typically used Titanium connecting rods, dry-sump oiling - the works. They make power from about 7,000 RPM all the way to 10,000 RPM. The M12/7 was always run vertically (straight up and down) as it was developed for formula car use initially.
    They made around 300hp.
    Bergrennen Tarmac Rally
    Marc Fleury S14 powered E30 drifting.
    Not really a fan of LS* engines, or swaps but this thing is an absolute beast.
    Build thread here -
    Mar 2011
    Daniel
    I know this is an older video but I still can't get over how awesome the Tedsport AE86 is.
    From Speedhunters.
    Gone is the trusty but comparatively slow 4-AGE. In it's place is a 2.5 Series 2 Millington engine which produces 318BHP and 230 ft/lbs from it's compact four cylinder, normally aspirated motor.
    Mar 2011
    Daniel
    BMW 323I
    Car Description
    K & J Racing built BMW E30 323I Sports Sedan Steel floorpan
    Make & Model
    1988 BMW E30 323I Sports Sedan
    Car Number
    99
    Class / Category
    Sports Sedan
    Engine
    Nissan SR20 2 ltr modified heads, forged ACL pistons, factory rods and crank , 90mm throttle body, 880cc injectors, ceramic coated exhaust manifold with Garrett 600hp ball bearing turbo with external wastegate, Autronic SM2 ECU and CDI
    Horsepower
    Approx. 550 bhp at 8000rpm
    Fuel
    103 Octane Unleaded - Fuel tank capacity - 60 litres
    Weight
    900kg (less driver)
    Suspension
    Front: Mcpherson strut ,adjustable coil over shock with Spax adjustable shocks, K-Mac camber/caster top hats, 3 way adjustable sway bar
    Rear: Adjustable coil over shock with Bilsteins shocks, K-Mac eccentric camber/caster bushes, 3 way adjustable sway bar
    Drivetrain
    5 speed Nissan close ratio, BMW M3 Group A IRS differential 4.1:1 or 4.5:1 diff gears
    Brakes
    Front: 14 inch AP rotors with Harrop 4 piston calipers, Competition Friction brake pads
    Rear: 12 inch Harrop rotors with BMW 735 4 piston calipers ,Competition Friction brake pads.
    Wheels
    Three piece 17' diameter Simmons
    Tyres
    17 ' x 10' Front & 17 x 11” Rear
    Aerodynamics
    Front spoiler, rear wing. sides skirts
    Top Speed
    Approx. 290km/h - depending on diff ratio.
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    probably the best thread to chuck this is. makes me want a e30 again even more.
    this has a 2L s14 engine
    Senior Member Panda BVB700's Avatar
    Jul 2010
    Brenton
    Woodend
    hows the side exit exhaust on that ls motor bmw
    adm ae86 now one hell of a project
    ae71 small project
    Mar 2011
    Daniel
    Italian/Portuguese 320iS. Rare car!
    Mar 2011
    Daniel
    1987 BMW E30 320i 1048BHP(1050nm) M5 3.6 Turbo
    Engine:
    M5 3,6l S36 Engine
    JE forged pistons (comp: 8,6:1),
    American Eagle
    H profile connecting rods,
    Arp studs,
    Custom camshafts
    Head Gasket Replaced with JM7 compression rings
    O-rings around all water and oil channels.
    Custom made intake manifold.
    Custom Intercooler,
    oilcooler in the boot.
    Autronic SM2
    Autronic CDI 500R
    Haltech coils
    Aeromotive fuel pump PN11102.
    Custom oilpan for drysump.
    Turbonetics turbocharger
    Suspension/Brakes:
    Front:
    FK / K&W coillovers with custom springs
    Uniball top mount (adjustable)
    Eibach ARB 23mm
    355mm Ap Racing brakes
    Rear:
    Koni dampers with custom K&W springs
    uniball top mount
    315 mm 4 pots
    Body:
    Heavily modified:
    Widened Rear Arches (about 16cm total) custom made in steel.
    Widened Front Arches (about 11cm total) custom made in steel.
    Engine is mounted 280mm further back for better weight distribution
    Carbon fibre roof scoop.
    Carbon fibre hood
    Carbon fibre trunk lid
    Carbon fibre/ Kevlar front
    Rieger side skirts
    Carbon fibre DTM spoiler
    Black lights with xenon
    New white paint
    Interior:
    Momo seats
    Sparco belts
    Wiechers Cromoly roll cage
    Carbon fibre door panels
    Dash logger
    Momo steering wheel with “easy off”
    Hydr. Hand brake
    Wheels:
    Leon Hardritte / Superstar Bugel
    9,5 X 18 ET 25 Front, 12 X 18 ET -25 Rear
    Yokohama A048
    225/40/18 front, 295/30/18 Rear
    Mar 2011
    Daniel
    I'm an avid fan of retro naked sports bikes and cafe racer style.
    Probably the best looking factory bike ever, is the KZ1000 MK2.
    This one has isn't exactly stock but the tank, tail, seat and side plastics are.
    One of my favourite cafe racer style bikes is the BMW boxers. Particularly BMW R45 and R65's.
    I've lost hours on this site.
    After I've finished my AE86 and E30, I plan to build a basic Cafe Racer style R65, since they're cheap and LAMS approved.
    Clip on handle bars, hidden gauges and small single headlight, single seat and matching tail, small exhausts that end where the frame meets the swing arm, black wheels and lowered suspension. Would be fairly rad.
    Mar 2011
    Daniel
    I want an E30 M3, so badly.
    Veteran Pidgey's Avatar
    Sep 2009
    Ry
    Sunshine Coast
    RE: BMW cafe racers.
    My dad had an R90 cafe racer in his day amongst a shit load of other bikes. I would argue against getting an R65 as the R90 was apparently way better? IDK, could just be dad's opinion.
    I will be building a cafe racer sometime next year from either a honda CB or suzuki GS.
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by Jacobxxx View Post
    I will legitimately drive nude...
  1. OniKyan's Euro Trash
    By OniKyan in forum Other Rides
    Last Post: 26th November 2011, 10:51 PM
  2. OZ HIP-HOP
    By raceAE86 in forum Offtopic Discussions
    Last Post: 11th November 2007, 09:34 PM
  3. Hip hop: Delta: The Lostralian
    By hachirokuGTV in forum General Topics (No Technical Questions)
    Last Post: 20th February 2006, 10:16 AM
Tags for this Thread
