Results 1 to 10 of 11
Thread: Anyone make custom hub adaptors?
    Senior Member jet111's Avatar
    Mark
    Default Anyone make custom hub adaptors?
    Ok so I have some wheels I want to run on my car with my new big brakes.. I have two problems.
    1. FC calipers hit the inside of my wheels
    2. wheel studs are too short for the new wheels
    I originally was going to use slip on spacers & long wheel studs on the stock hubs... however slip ons still dont give me enough clearance.
    I am now thinking of getting hub adaptors (20mm). However the studs will still be too short!
    So pretty much I need some hub adaptors with long studs, anyone know where I can get some?
    I have also thought of buying a pair of adaptors, punching out the studs and fitting longer ones. But I dont know if that would be a good idea since they are all made of alloy. Also im not sure if the studs fitted to the hub adaptors are the same as the stock Toyota ones... Could pose a problem when mounting new studs.
    What are your thoughts?
    Glenn ke_70's Avatar
    Clay
    Barossa!
    cant you punch the studs out of your hubs and put longer ones with abigger slipon?
    Senior Member Stain's Avatar
    Derek
    Far North
    im confused. how are your wheel studs too short for a bolt-on spacer?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    they would be too short because they need to go through some long slip on spacers and then the wheels.
    If you get these make sure they are very nicely fitted to located on the center ring of the hub and also the middle of the wheel, hub centric as they as.
    Heres some stud lengths:
    sounds like bolt on spacers would be easier
    Derek
    Far North
    i know the studs would be too short if they have to pass thru a sizable slip-on spacer first.
    as I had the same problem with my SSR MK3s and large brakes... ended up using a 10mm slip-on and landcruiser studs for the extra length.
    but if he's going to use a bolt-on spacer the length of the studs in his hubs won't matter. and if the studs in the bolt-on spacer are too short then something is very strange with the wheels...
    Mark
    My wheel studs are not too short for a bolt on spacer. They will bolt on no problem.
    The studs on the bolt on spacer are too short for the wheels. To fit the wheels I want, I need longer studs.. Therefore the studs on the bolt on spacer itself need to be longer, this is where the problem lies.
    To use these wheels I need bolt on spacers with extended studs.
    A 10mm slip on will not give me enough room. I spaced out the wheel 8mm and they were still fouling on the caliper fairly badly. I need at least 15mm clearance.
    I wont run anything over 10mm that isnt bolt on and hub centric.
    So the problem still lies .. unless I get different wheels, which I dont really want to do.
    Derek, what brakes are you running?
    Clay
    Barossa!
    new studs in bolt on spacers will be fine.
    Derek
    Far North
    I'm using R32 4pots. You shouldn't have a problem as most bolt-on spacers have fairly long studs.
    But I'm curious what rims you've got that need such long studs? I hope this isn't your problem;
    Mark
    Thanks Clay.
    Shit... I didnt even think of this, that might be the problem!
    The wheels are old school classics, but they are Australian old school classics. Looking at their website those wheel nuts do look like the ones you mentioned Derek..
    The wheels are "4 Spoke Draglights"... Let the haters hate.
    Ill send Dragway an email to see if that is the problem
    Derek
    Far North
    urk... save yourself the effort, turn those horrid things into a garden hose reel and buy some nice rims that have enough back spacing to clear large brakes!
  1. Replies: 5
    Last Post: 9th September 2010, 09:15 AM
  2. Does anyone still make custom springs?
    By KePtrick in forum General Topics (No Technical Questions)
    Last Post: 10th February 2010, 07:07 AM
  3. Replies: 21
    Last Post: 4th July 2009, 02:25 AM
  4. Perth: AE86 PWR Custom Radiator, Custom Tailshaft
    By Blown86 in forum Car Parts For Sale
    Last Post: 23rd August 2008, 07:16 PM
  5. wheels/adaptors
    By japlish in forum Car Parts For Sale
    Last Post: 21st April 2008, 09:42 AM
