Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: Recommended Engine rebuilders in VIC
  1. #21
    Aug 2010
    Geoff
    mt dandenong
    buy all your own parts and get the shop to use them?
  2. #22
    Apr 2012
    S.E
    Both of the 'cheap' workshops did say that they replace pistons and some other parts as part of the quoted $1500 cost. Though one is a huge workshop which has a high volume of output, so I suspect that they would simply build a block that 'does the job', as opposed to one that stands out.
    I'd have to get the shop to check if the block needs boring first, no point buying pistons that are too small or big. Easiest way is to let the shop pick the parts with the best fit.
  3. #23
    Aug 2010
    Geoff
    mt dandenong
    so your supplying parts or not? i'd go speedworks, thats who i'll be using when i get some work done to my engine
  4. #24
    Raymond
    Eastern Suburbs
    As mentioned, I will be supplying everything. The quotes are for me supplying everything from oversized pistons, rod bolts, main bearings etc.
  5. #25
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Dandy Engines are good, but I doubt they would have much experience with 4a's to be honest.
  6. #26
    Apr 2012
    S.E
    I've been trying to ring speed works , no answer. Are they still closed for the holidays?
  7. #27
    Adam
    I used Dandenong Rebores to do the head on my 18RG and they were excellent.
  8. #28
    Senior Member Water Boy's Avatar
    Crank shaft rebuilders in Blackburn.
  1. Recommended Vic Engineers place
    By rthy in forum Melbourne & Vic Events and Discussion
    Last Post: 19th March 2013, 10:52 PM
  2. NSW Engine Rebuilders
    By blakey in forum Sydney & NSW Events and Discussion
    Last Post: 19th September 2011, 11:54 PM
  3. Recommended Engine Workshop?
    By blair in forum Brisbane & QLD Events and Discussion
    Last Post: 24th December 2009, 06:47 PM
