should be ideal mate. watanabes in 14/15x8 up to 14/15x9 all look pretty good on ae86's. the sizes you mentioned shouldnt need too much of a roll if any to fit when low
will this work or recomendations please
Watanabe r type 15x8 -0 or 15x8.5 -6
AE86
Standard LCA
shock works coilovers
spirited drive willwood brake upgrades
jdm T series rear in the near future
plan on running it as low as legal for qld and dont want to scrub if i can
this is 15x8 zero all round just to give you an idea
cheers this is exactly what i was after THANKS a heap
Hi guys I've got an ae86 trueno coupe I want to order some 15 inch work equip 03 on stock guards I don't mind rolling them but I'm not going to flare or fit bolt on guards. From what I can find on this site and info I've seen people seem to fit 15x8 -6 o disk on the front and 15x8 -6 or -18 o disk on the rear but I haven't had a full confirmation on it can anyone shed some light thanks I'm trying to get the most dish I can fit on the car for that good fitment look without too much scrubbing thanks guys
as long as the car isnt too low (tucking tyre) 8 -6 will be fine with a 195/50 tyre. You will have to roll the guards though and probably remove the front plastic guard liners. Depending on how much castor you are running to may have to trim the bottom of the front guard for it to clear as your turn the wheel.
Thanks konakid what do you think about 15x8 -18 o disk for the rear of the car????
will poke out from the body line by about 10-15mm and will rub a lot. The -6 will sit even in line with the guards.
I've tried my best to search online and the forum, with no luck so apologies if this has been asked and answered before - Does anyone have any examples of TE37V fitment on a AE86? I'm tossing up between 15x7.5 front 15x8 rear, but I haven't been able to find a lot of fitment examples online (plenty of examples without wheel details).
Thanks in advance.
those widths are easy to fit steve,comes down to offset and how you want them to fit
