front, ke70, 30mm extra track each side, fit a 15x8 -10ish under metal???
Will 15x8 0 offset fit under stock guards after a slight roll, probably run 195/50's? Car sitting on lovell super low's (Dropped 2inch's)
not with like -654 camber!
15x8 +0 is fairly flush with stock lca's. work from there
I have 14x8-15 stock guards and xt130 lca's -2 camber, are you talking s13 gear still Michael? 30mm with s13 lca's?
yep s 13 LCA's are about 30mm extra from memory
Do r31 lca, fixes too much track issue and can fit 15x8's with a roll!
i want the wide look, like GET FUCKED wide look
So anyone feel like answer my question lol :p... top of the page.
15x8 0 with 195/50 will fit but cant really go that low without haiving stiff spring rates
Will need to roll guards yes. Rolling guards is pushing the lips flat on the inside edge, no point in slightly rolling the guards, you either do or you dont.
Ahh k that makes sense lol. Springs are 6kg... think it would be fine sitting as it is(lowered 2inch)?
