If that V8 is based on 2 Yamaha-R1 mated at 90 degrees and revs to 15 grand![]()
Word is Toyota is planning a V8 version.
Maybe they might go a H1V8. Google it if you're unfamiliar. 2 Hayabusa heads with custom block, flat plane crank, 84mm bore and 63mm stroke, 75º vee angle, dry sump. 400hp @ 9500rpm naturally aspirated, from a 2.8L. That's with the head being completely stock too, with porting and some aftermarket cams they reckon up to 500hp is possible. Small engine too, only 550x550x450mm apparently, giving it a real low centre of gravity.
Pity the makers of it want AU$40k a piece...
Something similar but 2l and Yamaha to keep it in the familycould be VVTi and named BEAMS2 (Hey Toyota engineers! are you taking notes?!?)
Regardless on what they call it and what they do with it, it couldnt be any worst than the trd aurion? Could it?
then i would whore myself out to 1000 fat chicks at 50 bucks a pop to own one.
