omg tough.............
maybe an inch lower max while still running the 10's.......you'd be surprised how little clearance you get running 145/80-r10 tyres!
once I put the new diff in an get coilovers done for the front....or even just source some inserts for my struts,I'll be getting a set of 13x8's for it!
I payed $300 for the new 10's for the rwc,so i figure I'll get my moneys worth out of them....sooo,getting some white walls done either tomorrow or moday....I'm thinking a thin double white wall?
Also,finally done some research and found the part number for a boss kit that fits...should also be here monday,I've got this little 13" shadow chrome sass wheel laying around.......I wanna get a 12" later but this will do.
43ger
Performance
SINCE 2008
43ger
Performance
SINCE 2008
Power pipe/Expansion chamber is done....pics up later.
Also a pair of coilovers are now on the drawing board...looking into possibly adapting some ke70 struts? whichever works out easiest! inserts for the st90 struts are the problem,no one stocks parts to lower these things!
I wanna go down another 2-2.5"..rear bump stops/chassis will need to be modded,flip rear leaves and adjust coilovers to match!
might need to look into a radiator sump,bash plate thing....everything is under the floor so once it's on its rails all that shit will be dangerously close to the ground!
although 13's should get it sitting lil higher.
I ended up sourcing an early VW golf gti 2-piece chin spoiler,Its plastic rather than fiberglass so should be a bit tougher also the dimensions are perfect!
it's another thing i can justify because of the ride height,lol....gotta get that air flowing to the radiator!!
so its actually practical!
43ger
Performance
SINCE 2008
omg that is awesome..
Your doing a good job of this thing man! Ride height is awesome
Picked this up as a bit of a project too......think I might have a classic Kei car addiction and/or osession right now
43ger
Performance
SINCE 2008
Update..Fitted some 2" lowering blocks before the last pics,and my chin spoiler arrived yesturday....
also picked up a pair of GT fender mirrors for the fellow max.....I'll look at getting it painted soon,but untill then.....
I bought a G200 mira for a more practical daily,well a little more practical anyway......It has 4 seats!
I was going to buy a W124 320E Mercedes sedan....but the mira popped up,and I had to have it!.....Oh and did I mention it has a jap spec TRXX engine conversion done?
I've been hangin out for that turbo rush like a junky to the steel!
43ger
Performance
SINCE 2008
Is that a perfect fit or is that a perfect fit!?
43ger
Performance
SINCE 2008
This is so cool!
