Now the bastard wont start.... It turns over and fires a little bit but wont stay running, fken bastard of a thing
SO EXCITED!
Looks like you have some good stuff going into your rig
Just another Muppet
Yeh i just need it to start up again , i checked the fault codes on the ecu and all i get is code: 55 , but that means everything is fine. It just coughs and farts and doesnt actually start. I think this might be a job for someone else.
OK car is fixed , it turns out my lift pump was wired in backwards and when the car started initially it was because there was some fuel sitting in the surge tank. Now ive swapped the lift pump so it runs the right way it starts and runs perfectly!!!! WINWINWIN!!
Woooo I love it!
Le updates?
No updates unfortunately. I blew a headgasket and the car has been sitting in my garage for months now. I have to pull the engine out again completely to change the headgasket because the rear exhaust manifold bolts are too close to the firewall to take out with the engine in the car. So im saving some coin at the moment to give the ca18 more goodies.
In the next couple of months i hope to have:
top end rebuild ca18det
t28 from an s15
braided turbo lines
oil cooler / relocater
alloy radiator
Will be cool! Good luck
