cheers man, will be doin that on sunday, will just sit it in there to see wat it looks like and mark out where shifter will sit and if i need/ want to cut the fire wall
Not bad. Patience is key when working on hondas. They are bitches. Can't wait to see the motor in the e7. Good luck
The lower n farther back the better. What do you think the weight ratio back to front will be with the f20c?
Yeah I wanna mount it back as far as I can and low. But gunna try do it without lowering the crossmember. So maybe solid mount so it doesn't have 3 inches worth of rubber mount then lower the crossmember 2 inches to make up for it. I'll work it out as I'm goin
Stripped heater core and pedal box. Now to remove the sound deadening. Anyone got any dry ice lying around lol
Ur going to regret removing the sounding deadening material when vtec makes ur ears pop
Is it really that loud. Maybe might leave it then. Want to remove it cause it looks like shit
just paint over it dude, looks great when its painted. i removed it once on a e30 and ended up putting it in again.
U guys think it's not to bad. Suppose wont really matter if I'm gunna run carpet anyway so u can't see the tunnel mods. That's if I mod the tunnel and fire wall. Will work these things out wen I get the chance to sit the engine in.
