Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 21 to 30 of 61
Thread: AE86 proportional valves (brakes n shizno)
  1. #21
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    yeah but theyre illegal which is the problem. im gonna have to get one but am gonna hide it in a black plastic box
  2. #22
    Senior Member n00bvak's Avatar
    Novak
    SOR
    it is just the adjustment that makes them illegal, well here in WA anyway. If you take the adjustment knob off them (it just comes off) and heat shrink some plastic on it then it is non adjustable therfore legal.
    This is what the guys at a performance brake place have been doing for years and registration has never been a problem.
    --- All your base are belong to Phil Bradshaw!!! ---
    <<< blog >>> build thread<<<
  3. #23
    Dan/Rio
    Randwick
    well thats what ill do smart guy
    seriously though, thanks for that info
  4. #24
    Veteran slydar's Avatar
    Dimitri
    you can buy in like proportioning valves from American speed shops. for disc or drum.
  5. #25
    Novak
    SOR
    Rthy, this is how we have resolved "blocking the front fluid getting into the rear" issue
  6. #26
    Elite rthy's Avatar
    Leo
    Tulla
    im aware of how how the adjustable pv works was thinking for getting the adjustable prop valve, but didnt like the idea of having aftermarket pv's when the car can be stock as a rock.
    so it safe to say no one has tried modifying the factory pv in away to block the additonal patchway to the rear.
    my plan b was to get one from america or europe.
    edit: first post fixed, want to use factory PV and not aftermarket ones.
  7. #27
    West
    Whats all the fuss about?
    You know what parts to use to make it as it should be, so just get them.
    Looks like no ones gonna explain it to you.
    I bought a halfcut to get my bias valves and a low klm gearbox from it. In the end I was paid to get them.
  8. #28
    Elite rthy's Avatar
    Leo
    Tulla
    the fuss is: has anyone modded the factory ADM proportional valves to suit JDM rear disk brakes? more to the point, has anyone cut an ADM pv in half and welded shut the connections between the Front and rear brakes?
    I assume not.
    maybe my 1st few posts wasn't clear on my intention, appologies for the confusions...
    looks like ill just do things the right way and get the jdm 2piece pv.
  9. #29
    West
    Well plenty of people mod them, by leaving out the spring, but I have a feeling its part of the tandem circuit failsafe that stops you losing all your brakes when one corner goes.
    Best to use what Toyota has designed for the job, failing that, the aftermarket gear which you aren't so keen on.
    Have a nice day.
  10. #30
    Elite rthy's Avatar
    Leo
    Tulla
    Found one of those rear brake T piece on the diff
    tried using it for the front brakes and the jdm pv to control the rear. the brakes work great now.
    made a small alloy bracket and bolted it to the factory location so that the splitter is not floating around
    factory adm pv
    altho would still be interested to see if anyone has hackeds up the adm pv...
    dont have anything agasint the adjustable pv, i just want to keep the car stockish, as for the ae71 dont really care cos its all going to be engineered.
  1. Blocked brake proportional valve
    By BARWICK in forum Technical - Questions
    Last Post: 25th October 2011, 06:53 PM
  2. Telling the difference between ADM and JDM proportional valves
    By jamekins in forum Technical - Questions
    Last Post: 1st May 2010, 01:29 AM
  3. [vic]JDM proportional valve
    By rthy in forum Cars or Parts Wanted
    Last Post: 23rd February 2009, 08:00 PM
  4. WTB JDM Brake Proportional valves
    Last Post: 28th July 2008, 05:07 PM
  5. Jap AE86 Brake Proportional Valve
    By Mr Fujiwara in forum Technical - Questions
    Last Post: 28th February 2006, 02:49 PM
