Fly on or not, it's kind of hard to bash a bearing through the crank shaft till it pops out. Might be there for a while.
I just find a socket that matches the bearing OD and bash it out the side that doesn't have the retaining lip with a hammer :/
This is assuming the flywheel's not attached to the engine of course...
Ah, so a 4A spigot's in the crank? Like a Magna? Fair enough
Carry on
newpaper + grease did it for me.
Use a thread cutting tap, i can't remember what size, but use one with an extra 2 or 3 mm on the inside diameter of the spigot bush, wind it in and it will bottom out on the back of the crank, keep turning and it will eject the bush. I tried the grease trick but tap will surely work.
