thats some helpful info thanks mate
Front spring rate increase:
More under steer; increase in proportional weight transfer to the front when rear wheel rate is not increased; reduces front traction when rear rate is not changed.
Usable adjustment: 150-600 lbs/in
Symptoms of too much adjustment: terminal under steer; front of car hops in corners; excessive wheel spin on inside front tire on FF cars.
Front spring rate decrease:
Less under steer; decreases proportional weight transfer to the front when rear wheel rate is not increased; increases front traction when rear rate is not changed.
Symptoms of to much adjustment: Too much over steer; over steer then under steer if spring is so soft that the car bottoms out on lean, car bottoms out excessively with a jolting ride.
Rear spring rate increase:
More over steer; increase in proportional weight transfer to the rear when front wheel rate is not increased; increases rear traction when front rate is not changed.
Usable range: 100-600 lbs/in
Symptoms of too much adjustment: too much over steer; sidestep hop in corners; twitchy; pretty scary.
Rear spring rate decrease:
Less over steer: decreases proportional weight transfer to the rear when front wheel rate is not changed; increases rear traction when front rate is not changed
Symptoms of too much adjustment: car under steers; if way to soft car under steers then over steers as car bottoms out on lean; car bottoms out excessively with a jolting ride.
Front anti-roll bar stiffer: more under steer
Usable range: none to 1.25 inches in diameter
Symptoms of to much adjustment: terminal under steer; lifts inside front tire off the ground witch can cause massive wheel spin on FF cars; also not good for most effective tire usage as inside tire is now doing nothing.
Front anti-roll bar softer: less under steer
Symptoms of to much adjustment: overstate scary; more like fun
Rear anti-roll bar stiffer: more over steer
Usable range: none to 1 inch in diameter
Symptoms of too much adjustment: Big-time over steer. Can cause inside rear tire to lift off the ground.
Rear anti-roll bar softer: less over steer
Symptoms of to much adjustment: under steer; slow and boring
Front tire pressure higher: less under steer by reducing slip angels on most tires
Usable adjustment: up to 55psi hot
Symptoms of too much adjustment: no traction- tire crowned so more under steer; adds wheel spin in FF cars; jarring ride; center of tire wears out
Front tire pressure lower: more under steer by increasing slip angles on most tires
Usable adjustment: not less then 20psi
Symptoms of too much adjustment: edges of tire wear quickly because tire is folding over; feels mushy; tires chunk because low pressure means heat build up.
Rear tire pressure higher: less over steer by reducing slip angles on most tires
Usable range: up to 45psi hot
Symptoms of too much adjustment: no tractionâ€â€tire is crowned so more over steer; bad wheel spin on FR cars; jarring ride; center of tire wears out.
Rear tire pressure lower: more over steer by incresing slip angles on most tires.
Usable range: not less then 20psi
More negative camber front: less under steer because of better lateral traction as tread is flatter on the ground under side load.
Usable range: up to 3.5 degrees negative
Symptoms of too much adjustment: poor braking; car is road crown sensitive; twitchy; front tires wear on inside edge
More negative camber rear: less over steer because of better lateral traction as tread is flatter on the ground under side load. More rear grip
Usable range: up to 2.5 degrees negative
Symptoms of too much adjustment: more over steer; car feels twitchy in back; tires wear out on inside edge; less breakaway warning when limit is exceeded.
Ride height to low (typical beginner mistake): car is twitchy with unpredictable dynamics. Bump steer make you life miserable.
Usable range: usually 1.5-2.0 inches lower then stock unless car has been modified to go lower.
Symptoms of too much adjustment: everything that could possibly go wrong: sudden over/under steer; twitchy due to bump steer; very harsh ride; premature tire wear.
Toe in – front: car is stable going straight. Turn in is average
Usable range: 0-1/8th inch
Symptoms of too much adjustment: car has slow twitchiness under braking; feels odd; kills outside edge of tires
Toe out – front: Car turns in well; works pretty well on FF car as they tend to toe-in under load.
Usable range: 0-1/4 inch
Symptoms of too much adjustment: Car is really twitchy under braking; car wanders on straight road; kills inside edge of tire
Toe in – rear: car is less likely to over steer when the throttle is lifted
Symptoms of too much adjustment: weird, slow, rocking movement in back; feels slow but still unstable; wears outside edge of tires.
Toe out – rear: Helps car rotate useful in low speed and slalom courses; very common on FF pro rally cars.
Symptoms of too much adjustment: not to good for street driving; causes lift throttle over steer; makes violent side to side rocking motions in the rear; tie wears on inside more.
Positive front caster: helps stability; suspension will get more negative camber when turning; reducing positive caster reduces steering effort. (Negative caster is not usable)
Usable range: 4-9 degrees positive
Symptoms of too much adjustment: can increase under steer especially in cars with wide low-profile tires. Can increase steering effort.
Single adjustable shock stiffer: Better turn in; better transient response; causes slower onset of over/under steer by slowing weight transfer depending on what end of the car is adjusted.
Symptoms of too much adjustment: suspension becomes unresponsive; ride gets harsh; car skips over bumps, loosing traction; Causes a big delay in weight transfer resulting in strange handling like under steer then late corner stage over steer.
Single adjustable shock softer: slower transient response; quicker onset of over/under steer
Symptoms of too much adjustment: car oscillates due to under dampened spring motion, like a boat. Car gets twitchy in turns. Feels unstable.
Taken from
and
should make it a sticky.![]()
I mean "pinned".![]()
Decent amount of info, however a lot of the information is discussed as an individual adjustment. Almost all suspension adjustments are interdependent. Thus changing one effects the other.
AE86 4AGE "Slowly but surely"
