Results 1 to 5 of 5
Thread: D1 AE86 spec
    Tuan
    Nsw
    Wetherill park
    HI
    I just to have a little read of what kind of set up does the D1 drive have on there AE86 Drift machine.
    does anyone know of any.
    here is one
    cheer
    Senior Member DRFTAE86's Avatar
    Ronald
    Yeh this has been around for a while. Theres a few other drift cars specs on that site too.
    Though i do find it hard to find detailed specs on D1 AE86 as well. So i'd like to see more links too.
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    if any1 cant be stuffed going 2 the site here the specs of his car:
    OWNER: Katsuhiro Ueo
    HOMETOWN: Tamanashi-gun, Kumamoto, Japan
    DAILY GRIND: Owner of Sift Racing Garage and used car dealership, oh yeah, D1 Drift Champion
    RIDE: '85 Toyota Corolla Sprinter Trueno AE86
    UNDER THE HOOD: 1991 4AG AE92-kouki motor, 1-4, 16-valve, 1600cc, 12.5:1 compression ratio, 82mm bore, 77mm stroke; Revolver GT pistons, rings, injectors, valves, header, exhaust; Toyota factory AE111 crankshaft and connecting rods, AE101 throttle bodies; Ueo Secret Type prototype camshafts; Matsuda SPL AE92-kouki cylinder head; TRD valve springs, Short Shift kit; Toda valve retainers, intake manifold, fuel rail, air intake, cam gears; Sard fuel regulator; Nissan CA18 catalytic converter, SR20 crankshaft sensor, Skyline GTR BCNR33 fuel pump; Tomei REYTEC ECU and ignition system; NGK plugs; Cusco Type RS two-way LSD; Exedy prototype clutch
    STIFF STUFF: Revolver Ueo SPL coilovers (90mm total lowering), front strut tower brace; Largus front and rear stabilizer bars; Cusco pillow ball mounts, rear lateral links, trailing rod assembly, adjustable pillow ball tension rods
    ROLLERS: Volk Racing TE37 14x7.0; Bridgestone RE01 185/60R14
    STOPPERS: iMAGE pads; APP Earl's lines
    OUTSIDE: Sift Racing Garage cream paint; j-blood body kit, hood, and rear wing; carbon headlight covers
    INSIDE: Bride Zeta II driver and Zeta passenger seats; TRS four-point harness; MOMO 350mm steering wheel
    ICE: Uh, no
    PROPS: Cusco, Yuke's, j-blood, Revolver, Tomei, Bridgestone, RAYS Engineering, iMAGE, Exedy, car boutique club, Largus, Defi, TRS, RH BULL, Pigutech, Wako's, Bride, Nishiokla Jidousha, JUN Auto Mechanic, BOZZ Performance, A'PEXi, LA, Yokohama.
    ps the sites also got a good story and pics to go with it
    Yang
    Salisbury
    Tuan
    Nsw
    Wetherill park
    hey alan
    is the same one as what i put up
  1. trueno d1 spec 1/4 panels
    By johl in forum Car Parts For Sale
    Last Post: 28th March 2008, 09:27 AM
