MMMMM. Nice.
I cant wait to get my new engine in so that I can start working on it.
You have any more pics?
Ok, about time i did this, cant be bothered transcribing all the buildup posts just yet. So instead ill be a complete bastard and just do this:
MMMMM. Nice.
Previous cars:
BMW 318i, Mazda MX5, Mazda Familia, Toyota Levin GTV (miss it), AE71, AE92 corolla x 2, Honda Integra Type R DC2 (awesome car),
Mitsubishi Evo 8 MR (Missing it)
Current Car:
2013 Hilux SR5 (turning it into a off-road warrior)
I am looking for a track only car..... Thinking of an AE86 to use.
nice brake bias adjuster
Sweet, what's been done?
Good work Takai, its starting to come together
Interesting that you decided to keep the booster, though you might have gone for a pedal box / balance bar arrangement starlight up
one thing to keep in mind is that with big cams & long periods of wide open throttle you may run into a scenario where you don't have enough vacuum being generated once you snap the throttle shut.
if your currently picking your vacuum up from 1 runner, a way around this is to tap into all 4 of the manifold runners and then combine the lines into a small storage tank that you can then hook the booster up to.
catch ya
Chris O
Takai, what sort of races will you be competing in and what brake bias adjuster is that?
Thanks Chris.
It is indeed coming together. And rather quickly now too. I did consider the possibility of going straight for a remote pedal box and ditching the booster altogether, and i have also thought about going to an unboosted master. But with my new found skills of bundy bending both of those are relatively simple prospects later on down the track. When i last had the car running i had a small resevoir for the vacuum and i was picking up vac off all four runners.
For now im going to ditch the resevoir and see how it goes, if i end up running short on vac ill probably just do what you were suggesting initially and ditch the booster altogether.
For those who were wondering what sort of racing ill be doing, ill be in the same series (Improved Production) as Chris, just a different state (SA). The bias adjuster is a Wilwood "screw until you can screw no more" bias adjuster, and is to get a fairly generic proportioning for front to rear happening. When I get some practice in i will also be using a 7 way lever type adjuster for corner to corner work.
Some specs and stuff coming... maybe
awesome, simply awesome
wish i had the time and money to race my car -sigh-
Just because i can :
Update
What M/C is that?
Also do you think the stock MC would be okay for JDM fronts and RT142 rears? (restrictor removed)
