Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: Diffs
    Dec 2005
    While im thinking about it,
    Im planing to take my diff apart this weekend, I havnt even gotten under the car to have a look at what diff i have (read: lazy) .. anyway Im thinking of putting some welding skills to use and locking my diff (provided it can be done?)
    Has anyone had any experience in playing with stock Aus spec diffs.
    If it easy or hard to pull out..
    any tips / instructions would be good too
    Jul 2009
    Kane
    Coburg
    there easy to pull out.
    but i heard they are a bit tricky to weld...
    anyway
    1. jack car up and put on stands
    2. take wheels off and take axles out
    3. un-do tail shaft bolts that conect to diff and let it drop.
    4. un-do all 8? bolts around diff centre
    5. un-do drain plug and drain the oil
    6. take diff centre out
    7. give it a bit of a clean(dont use degreaser as it will f*** your bearings)
    8. weld the small cogs together in the very centre of diff
    9. clean it up again (all the slag etc)
    10. put it all together opposite to how you pulled it apart.
    this is a quick post. but im sure there is a more detailed thread in the tech section
    lol
    ps. this should be in another section.
    Junior Member Batesy's Avatar
    Simon
    Queensland
    Townsville
    Ive welded my aus spec diff up and i can say its a bitch todo!!!
    The Aus spec center has to be pulled apart (I.E. you have to take the crown wheel off and also undo the center where the spider gears live)
    Its not hard, just time consuming.
    I took the spider gears out (and left them out) and just welded (Read: Sh*t loads of weld) the side gears to the centre housing
    good luck
    -Simon
    BTW, my car has been locked for a couple of months now and it seems fine
    Jason
    Gold Coast
    i think u have posted in the wrong spot dude (for sale not tech)
    Senior Member Medicine_Man's Avatar
    Justin
    North
    Moved to correct section, gosh I wish people would read first before clicking away madly..
    Why hesitate when you can accelerate???
    Yellow 1984 KE70 Corolla, 1.3L 4K-C, Tighe 104 Cam, Electronic Dizzy, Dellorto DHLA40s,
    4-1 Hurricane Extractors, 2" Exhaust System, 5 Speed, Factory Mags, Towbar, 33 RWKW Last dyno.
    My free plug
    Just use the first 3/4
    Senior Member DRFTAE86's Avatar
    Ronald
    Weld it up good
    Ronald
    closer look
    Senior Member Sprinterboy's Avatar
    Justin
    DC
    Downtown
    USA
    man, you should FILL IT! not just weld the gears togther, ok it works, but i put some old bolts and stuff in there and fill the thing with weld! to neaten it up i plate the sides too. looks nice and pro! lol
    Dec 2005
    I posted this in the for sale secion? damn my bad.. i was in a rush and thought i was in the tech section.
    might start pulling it apart tomorrow
    thanks for the input
    btw, whats the benefit of throwing bolts in, just makign it tighter?
  1. diffs???
    By MR86ER in forum Technical - Questions
    Last Post: 24th June 2010, 10:12 AM
  2. diffs
    By rolla92 in forum Technical - Questions
    Last Post: 25th April 2009, 05:28 PM
  3. Diffs?
    By jamekins in forum The Drift Channel
    Last Post: 2nd January 2009, 10:33 AM
  4. diffs diffs diffs
    By ae71 drifter in forum Technical - Questions
    Last Post: 21st September 2007, 01:46 PM
