Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 40
Thread: Jap AE86 Brake Proportional Valve
    Tom
    SOR
    Hi guys,
    Anyone actually own a genuine JDM Ae86? Is the brake propotional valve on them a staight bolt on replacement for Aus ae86? or is the brake line all different? a picture would be great.
    Thanks
    Apr 2011
    Steve
    The valves look the same but the internals are slightly different.
    Sprinter Veteran
    anz
    the valve looks totally different
    u can still buy these brand spankin from toyota
    bolt straight in
    brake line is the same
    from memory...
    Jan 2006
    How can it be the same when the aus has rear drums and the JDM has disc rear ?
    I think SprinterTRD is right and from my memory they look a bit different to
    Maybe PM snake66 as he will have one removed atm
    Apr 2011
    Steve
    I fited one from a Celica with front/rear disks to my car and they look the same as the sprinter drum ones. They even have the same bolt mounts. Its the internals that are different to allow for the different pressures between drum & disk setup.
    Sprinter Veteran
    Scott
    ACT
    Braddon
    might i ask if you have the part number??!
    Senior Member ae86 drifter's Avatar
    Pete
    is this the value that mounts to the strut tower???
    ROYAL GARAGE NEWCASTLE
    Ferny Grove
    i have read somewhere (i wish i could remember where), that you can pull the guts out of a local one and it gives the right pressure to the rear discs, don't quote me but!!
    Ian
    NOR
    i used to have pics of the two types but i cant find them anymore
    will try to take some pics, but its pretty hard to get a good view with the engine in
    Jan 2006
    Straight bolt on and deadly
    What the pressure/fluid displacement difference between a drum piston cylinder and a disc piston
    Basically i would love to see someone try to do a emergency stop in the wet with a aus valve in a jdm unless they have very crappy pads or seized rear calipers in the rear there car would swap ends so fast it isnt funny
    Both aus spec and Jdm valves already have a slight rear bias in the case of the 86's i have driven , adding a drum brake valve to a rear disc Jdm car would make this worse . You can make this better by balancing this back with better front pads .
    Play it safe and if you are really unsure get a brake place to bench test the valve and its pressure Don't just go of someones internet advice as you are playing with your life
  1. 4age 16v jap big port rebuilt, jap tseries disc brake
    By 70rolla in forum Car Parts For Sale
    Last Post: 4th September 2012, 11:29 PM
  2. Blocked brake proportional valve
    By BARWICK in forum Technical - Questions
    Last Post: 25th October 2011, 06:53 PM
  3. Brake master for jap ae86
    By Tim.duncan in forum Technical - Questions
    Last Post: 6th April 2009, 08:33 AM
  4. [vic]JDM proportional valve
    By rthy in forum Cars or Parts Wanted
    Last Post: 23rd February 2009, 08:00 PM
  5. WTB JDM Brake Proportional valves
    Last Post: 28th July 2008, 05:07 PM
