Um
castor - pull bottom of the strut all the way forward (dont know if negative or pos)
camber - 2 degrees NEGATIVE!!
toe - neutral
Thats my settings.
I have heard that the best settings are:-
CASTOR- maximum positive
CAMBER- positive 2deg
TOE- 1.5-2mm toe-in
What do you recomend, or what do you run in your AE??
Cheers,
Justin.
Um
toe - neutral
Thats my settings.
agre with Neo, don't know where you got those toe and camber settings AE86 represent, but they are far from desirable.
yeah def hav -2 camber not positive
a bit of toe in can help your tires wear a little more evenly with the highish amounts of neagtive camber most of us might run.
78's
