yea so I was installing the H4 HID kit into my 86 but then I found the manuel says there is a wire called polarity adjsuter which you'll need it connected between the bulb and the ballast if your car has a positive(+) current and you don't need it connected if your car has a negative(-) current. Are our cars positive or negative current, should I connect it?
