Results 1 to 9 of 9
Thread: Installing Pistons - Building a 4age Part #3
    Sep 2009
    As promised.
    What you need.
    Hot Soapy water
    Oil
    Rag
    SuperCheap (super shit) ring compressor
    Hammer/Plyers
    Time.....
    Ok, so firt go and install the rings onto the pistons, im not going to bother becuse there step by step on the pack.
    Then wash you bored with some hot soapy water, clean all the crap that built up off it and all the old oil, honing greese and shit.
    When you think its clean get a white rag with some clean oil on it and see if it comes out clean, if not keep trying.
    Sep 2009
    Oil you shitty ring compressor so the piston can get out smooth
    Now, get your shitty ring compressor and tighen it up.
    Line up the end of the compressor about were the little ridge on were the gudgen pin sits.
    Sep 2009
    Now for the bad bit
    I carnt stress enough do not force the piston in. I did this and i snaped an oil ring, really gay waiting 1 week too get another one.
    Ok line your piston up to thr front, the arrow goes to the crank wheel.
    Slowy feed the piston down into the bore, with the aid of some new engine oil.
    Now slowy tap the compressor into the tapped bit of the bore, you must not be able to see any part of the piston otherwise the oil ring will slip out (found out the hard way....)
    So slowy push down with your tumbs and the piston so slip in, with a bit of resistance.
    This will take a long or short time and probly have to try a couple time before you get it in i know i did
    ANy way...
    Sep 2009
    O btw make sure you have installed the conrod bearings
    Once you have got it in, line it up with the crank and install the rod cap.
    The torque for the bolts is : 49-nm
    Done!
    Me>56k
    Adam
    New South Wales
    fix the pics?
    Veteran Klutch's Avatar
    Feb 2010
    Was made in 2006 dude, pics are probably taken down/expired.
    Jonathan
    I can't even remember back to 2006.
    Adam
    New South Wales
    i need to know if the rods marking should be point the front of the engine or the back. Front=crank pulley back=clutch ??
    Brendo
    pretty sure the arrows point to the front ie. crank pulley...its been a little while since i pulled an engine down
  1. installing 4age
    By 4a-cnt in forum Technical - Questions
    Last Post: 12th December 2007, 05:10 PM
  2. Building a 4age - Valves
    By Rich_86 in forum Technical - Articles
    Last Post: 7th May 2007, 04:38 PM
  3. Building a 4age - Crank
    By machg in forum Technical - Articles
    Last Post: 21st October 2006, 07:18 PM
  4. Building a 4age - Pistons
    By dr1ft-pig in forum Technical - Articles
    Last Post: 9th April 2006, 11:14 PM
  5. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
