any remote filter setup for a 3/4-16 thread oil filter will suit any 4A engine, 20V is no different.
Has anyone seen a remote oil filter setup for a 20v?
Any info would be great!
they prety easy to get to standard y change ?
Firstly the oil filter is right in the way of where i need to put the engine mount for my ke25, and secondly id prefer a larger capacity oil filter sinse it is a race car.
you can use a Z158 on them instead of the Z386![]()
I read that the sr20 kits fit. I would confirm it first though.
You can get the spin on adapters from meridian motorsport too.
the SR20 kits don't fit. The CA18 kits however do fit 4A engines, just jap sell remote filter and cooler kits at around the $400 mark. Try the nissansilvia.com forum for a good deal.
remove the oil filter extension housing off the 20v and fit a non oil cooled 4ag or 4ac oil filter fitting to the block. then you can put you filter straight on the block just like a normal 4ag.
78's
