Quick release steering hub! only problem is, well ever seen one of those tools walking around with one of the wheels off their pushbike?
Besides buys expensive alarms etc. etc.
Does anyone have any good ideas for cheap anti theft systems? i want something easier than just pulling out the ECU and carrying it away, as this will get a little annoying after a while.
I currently have a stock 4AC and pulling out the rotor button and putting the cap back on is easy as pie, but ill soon have an SR in there and havent thought of any "kill switch" ideas.
NOTE: isolater switches dont count, unless they are somthing fansy
Even better is pulling the coil lead every time you get out of the car and put it in your back pocket. it is highly unlikely that a thief will have one in their back pocket! Same as the rotor button, but faster. It's a bit hard on an SR though.....
I did this at one stage "removing lead" and found that upon attempted start up you could hear it ark out, and therefor instantly know the problem. with a simple swap of a lead, your off (running on 3 cylinders), what a score!
rottweiler?
The obvious batterty switch hidden underneath the carpet usually works.... Great idea if your battery is in the boot....
Also, considered a tap on your fuel line... One of my mates has this, you dont get far down the road....
Best solution is to pull the EFI relay fuse...car cranks but no start bro. But really you umm not be talking about this on a public forum...duh
take out your diff
Thread should be deleted after couple days
Soon car theives be bringing tool boxes with them , their going to know what to look for now
btw u can buy your own wheel locks if you really wana go to extreme,like one that ticket guys put on your car for outstanding fines
Dont need to make your car un-stealable (which impossible anyway) you just need to make it look harder to steal than the car next to it.
If you are going to remove something a fuse is too easy, it would probably be the first place they would look if the car doesnt kick and you could replace it with a $0.01 paperclip.
