Thats funny man....... shit, so it even feels ok with the stock master....
noticed your thread on nissansilvia.. lol..
yep just googled it,
257mm = CA18DET, SR20DE
280mm = SR20DET
so i do have SR20DET brakes on my car. feel alright though obviously as i have stated in the past, that's using a 13/16ths master instead of 15/16ths. i tried hell hard to lock the rears when i got it all running and it wouldn't same as in the wet wouldn't lock up!!?!?!?!. i could fit 14's over them as well.
hmmm, i'll have to swap them anyway my engineer already knows about me running bigger brakes and will research the measurements to ensure i am running the right master cylinder, he is thorough........
and umm obviously my front end conversion hasn't been approved yet.
Got hubs and LCA's today....
Just wondering if your rims fitted on the S13 hubs as the center is bigger and wouldnt fit the MA61 rims or the stockies I had lying around......
or did the rims need some maching or Spacers ect..?
my rims fit fine, never tried a stocker though as they wouldn't clear the brakes. i 'll have a closer look tomorrow when it's light and see what the go is.
yeh I think it may have just been that I didnt have the rotors on... just tried the hubs by themselves..
also another thing Im a little confused about.... the rotors I have' have 2 threaded holes along with the 4 that the studs go through... how is the disc secured as there are no holes in the hub for any bolts to go into...? wtf... or is it simply held in place by the caliper...? ( I think highly unlikely ) I dont have the backing plates either...
(oh yeh this is the SR20det rotors) which I have since decieded to use again....
Dont worry about those small 2 holes.
They do nothing that will be of concern to you.
so how are the rotors held in place...?
Gaffer tape...
The wheel holds it on. And the centre hub ring keeps it located.
cool..... cheers man... I had the feeling that was the case but after seeing a few other hub/disc setups I was a little sceptical..
