Sounds like a vacuum leak..
I had this problem in my skyline .. but it was BOV issues.
im pretty sure this wont be your case, as im sure you dont have a BOV ..
but check all your vacuum in depth and makre sur eyou got no gasket leaks
hey, ive just put a silvertop into my ae93 seca, the car idles but as soon as i touch the throttle the car stalls im guessing i put the vacuum hoses on wrong, any one had this problem before & the correct way for the vacuum hoses
ps i dont have a starter relay cause it shitted itself so i bridge it at the relay to get it to start
would a vacuum leak cause the car to stall when you put your foot on the throttle ?
