Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 40
Thread: JDM ae86 levin hatch
    Veteran slydar's Avatar
    Dimitri
    78's
    Brad
    Central coast
    that looks sick!! not to many blue ones around, what size/offset are the wheels?
    Senior Member Medicine_Man's Avatar
    Justin
    North
    Looking tops
    Why hesitate when you can accelerate???
    Yellow 1984 KE70 Corolla, 1.3L 4K-C, Tighe 104 Cam, Electronic Dizzy, Dellorto DHLA40s,
    4-1 Hurricane Extractors, 2" Exhaust System, 5 Speed, Factory Mags, Towbar, 33 RWKW Last dyno.
    Dimitri
    the wheels are in great condition mostly, but are missing their size/offset sticker.
    theyre an older wheel though, some of the higher magnesium content.
    ant told me they were 8's when he originally purchased them in japan from up garage.. but the amount of stretch makes me think theyre 8.5.. they measure 225mm from lip to lip. rim width though is measured inside, and i havent had a tyre off.
    but atleast 8s. and single digit negative offset.
    i really just guessed at what id need guards wise to fit them. worked out good
    rear wheels will actually sit a tiny bit closer to the guard at the rear, panhard bar need ajusting.
    78's
    Mar 2010
    mark
    qld
    brisbane
    that looks awesome man!
    Spec us up. what motor/susp etc etc?
    Veteran slide86's Avatar
    Huw
    Hills
    looks good D
    motor still running ruff?
    Dimitri
    front - tockico hts 102 dampner 25mm shortened and coilovered strut cuscos high castor tops 350 lbs spring offset rca. pillow tnesion rod quaife quick rack, power steering arms, modded rack housing/rack ends for more lock.
    rear is brand new xf falcon coils cut down, trd 8 step green dampners, traction brackets, trd bushes in lower arms, t3 lateral bar.
    drive line is jdm big port with hks 264 intake/256 exhaust cams, vernier gears thin gasket, chipped ecu, set of generic jap headers that came on the engine, 2 1/4" section welded slydar spec exhaust with semi straight through centre muffler and apexi rear cannon.
    reco'd os giken super single clutch
    os giken lsd with 4.6 final ratio.
    trd short shift.
    motor ran smooth, but developed a knock.. still runs smooth, with a knock.. hah. ohwell. will sort it one way or another didnt happen at high rpm so should be able to repair it fairly cheaply.
    78's
    Mar 2005
    sounds like a beast....... looks good 2....
    what type of skirts are they........? for some reason they look a lil different to most................
    Ferny Grove
    sweeeeet, did you finish it all off that day i came in? (thursday i think it was i have no concept of what day it is anymore as i work weekends) Brett's coilovers rock my world!!!!!
    rims look sweet as, leave them black.
    don't reveal the identity of the side skirts, see if anyone can guess.
    hungry jacks mario keyring FTW!!!
    Mar 2006
    where do you put your surf board?
    looks greatastic
  1. Wtb- jdm ae86 levin hatch,
    By skin in forum Cars or Parts Wanted
    Last Post: 19th March 2012, 01:51 PM
  2. Jdm panda ae86 levin hatch!! (adelaide)
    By toddheart86 in forum Cars for Sale (Toyota Only)
    Last Post: 2nd December 2010, 08:39 AM
