Results 1 to 10 of 13
Thread: Can i swap a 4age in my 87 sr5 coupe?
    Oldschool Member
    Oct 2006
    if you can swap this engine please somebody tell me everthing i gotta do and the price range for the swap
    Elite rthy's Avatar
    Leo
    Tulla
    its a pretty manageable job, I think you should be able to find everything you need by doing a search for "4age conversion". I don't think many could help you with the conversion costs though seeing that most of us are from Australia.
    Hey I am curious how common are ae85/ae86s over there?
    Oldschool Member
    Oct 2006
    ok i'll try that, but i never see any in my state. i live in maryland USA , their big time know on the west side
    Veteran biggo's Avatar
    Nick
    Noosa
    hahahahaha
    in short yes
    Veteran slydar's Avatar
    Dimitri
    haha in short half the noobs here have couldnt even pic that youre from the states.
    in short yes, but you will need to find a donor car as youll need the gearox and tailshaft (drive shaft) aswell as the dash and body loom, rear loom (or just add one wire to yours for fuel pump) fuel tank ect.
    as this in beginners section of club 4ag to get a better answer. this is an australian forum. we dont have sr5s here.
    78's
    stefan
    vic
    eastern suburbs
    sr5's are our aus spec(correct me if im wrong) but they have trueno headlights, in the us they have both, the corolla gts is the 4age version, lsd etc etc
    Elite rthy's Avatar
    Leo
    Tulla
    3au?
    stefan
    vic
    eastern suburbs
    pulled from
    just a FYI for us ignorant pple
    SR5 Specs
    Horsepower: 70 bhp (52 kW) @ 4800 rpm
    Torque: 85 ft·lbf (115 N·m) @ 2800 rpm
    Weight: approximately 2200 lb (998 kg) to 2400 lb
    Engine: 4A-C, 1587 cc
    Engine Type: SOHC 8-valve Inline-4 Carbeurated
    M/T Transmission: T50, 6-bolt flywheel
    A/T Transmission: A42DL, 4-speed overdrive w/lockup torque converter, mechanically controlled, with electronically engaged overdrive
    Compression: 9.0:1
    Differential: 6.38" Open with 4.10:1 Ratio, 2-pinion (Automatic) (S292) or 3.91:1 Ratio, 4-pinion (5-speed) (S314)
    Wheels/Tires: 13x5" +33 mm Offset Rims with 185/70-13 Tires
    First 7 Digits of VIN: JT2AE86
    Dimitri
    ok. youre wrong.
    jap sr5s have a 3a (1.5 litre) and use a k50 gearbox (cable clutch) and as such a differant tailshaft.
    i dont know about your source either. is the site u.s or european based?
    as for headlights all usdm cars are us pop up head lights. and cars you see from there that have fixed lights have been converted.
    78's
    Alex
    St Lucia
    I know theres a site with good SR5 conversion articles. It might be 4AGE.com (or whatever it is) or maybe you will have to spend 10 minutes or so with our good friend google searching...
  1. F/s or swap SR20DE Datsun 1200 coupe NSW
    By louix in forum Cars for Sale (Not Toyotas)
    Last Post: 6th July 2012, 11:44 AM
  2. celica ra40 coupe 5speed fs/swap
    By greatmelinko in forum Cars for Sale (Toyota Only)
    Last Post: 25th February 2011, 03:12 PM
  3. Question for US SR5 owners ...
    By ahines in forum General Topics (No Technical Questions)
    Last Post: 15th August 2010, 11:25 AM
  4. wanted/swap: levin coupe boot
    By poh_86 in forum Cars or Parts Wanted
    Last Post: 4th July 2007, 03:17 PM
  5. My 87 levin.
    By yordy in forum AE86 Owners Forums
    Last Post: 25th October 2006, 12:10 AM
