ran mine down to "the light" today and didnt find any problems with it......so the setup we've got running seems to work alright. just gotta quiet the b@stard down now![]()
i dont run a surge tank on my ae71 thrasher, i dont find it surges until you get it pretty low and throw it sideways, particularily right handers.
use the ae71 tailshaft when mating a ADM or JDM T50 to a KE70/AE71 borg diff.
Ae86 tailshaft will only work on the s and t series diffs which from memory have a different bolt pattern, i think 2 bolts fit, but thats not overly advisable.
diff combinations found the link above, as written by some awesome dude.![]()
can i use the 86 t50 ,and 86 diff and tailshaft for a ke70 , and the clutch lines slave cylinder n master lies n cylinder
it says that in the first post.........................
does the 16v have the same setup as 20v?? like would this work with a 20v aswell??
not really. find one of the many threads on putting a 20v into an 86. same deal as with the rollas.
hey gilly if u still need the bits i can help u out with:
86 gearbox x member
86 clutch master
86 rubber engine mounts
and the steel engine mounts
if interested just pm
cheers all
jimbo
Here is a "how to" guide on fitting a lift pump to original 4ac fuel tank pick ups.
Courtesy of Rollaclub:
If I was to use a vl lift pump and a vl pressure pump what would keep the pressure regulated
