Results 1 to 10 of 12
Thread: prize for this answer! s series diff info
    Oldschool Member
    Oct 2006
    hey,
    is there anyone in brisbane that has an s series diff or diff centre for me to have a look at?
    either accessible under jacked car or off car.
    only need 10 minutes.
    would be much appreciated!
    Dec 2005
    aht you need to know.
    I got one sittign in a box here.
    Oldschool Member
    Oct 2006
    pm sent monk
    Oldschool Member
    Oct 2006
    i need to know the bolt spacings centre to centre,
    from one bolt to the next in a circular direction around the diff.
    should be 8 measurements.
    best measured with digital vernier calipers if centre
    still in diff housing
    or
    if centre out of housing then just a decent steel ruler.
    Oldschool Member
    Oct 2006
    $10 to the person who can measure this for me via direct deposit!
    i need it to be precise though, so vernier calipers would
    be needed, just centre both vernier points on the bolts being measured
    by eye (as best as possible).
    *** will be 8 measurements, 8 bolts = 8 bolt spacings (as stated above ^^^) ***
    Veteran slydar's Avatar
    Dimitri
    61 inside 77.5-78 outside.
    78's
    Ferny Grove
    ^^^ desperate for cash D?
    Oldschool Member
    Oct 2006
    diagram
    Dimitri
    re money. dw about it, if youre in qld and you ever come to the shop you can buy me a drink or something. spacing will be all the same... ill check later today and write back.
    p.s yes gilly, should have stitched you up more on the over fenders. haha.
    78's
    Sep 2009
    lol watts linkage ?
  1. F series Diff info + Discussion
    By Konakid in forum Technical - Articles
    Last Post: 6th July 2019, 01:34 PM
  2. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  3. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  4. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  5. Info on F series diff ratios above 4.3
