Page 10 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 91 to 100 of 111
Thread: SA Track Times...well Mallala then!
  1. #91
    Moderator Frak's Avatar
    Jamie
    lol!! good to hear it's going well, good info aswell. hey will have to catch up soon.
    Hachiroku since 1994
  2. #92
    Josh
    first time out at mallala on the week end started off with 1:40s and managed to get a 1:29s at then end of the day.
    Engine - Big port 4AGE, exhaust , TRD fuel trim
    Power - unknown
    Brakes - F: honda civic caliper unkowen pads, R: JDM rear disc unkowen pad
    Suspension - F: -CRUX engineering suspension. Coilover front unkowen spring rate
    -Revolver negative camber RCA's.
    -Adjustable lower control arms.
    -Cusco front swaybar.
    -Sleeved tierods.
    -Carbing Front strut brace.
    R: -Equal length adjustable upper arms w/ "all internal" box section CRUX engineering suspension unkowen spring rate
    Diff - 4.7, TRD 2 way
    GBox - T50
    Tires & Rims - F/R:Light weight NCHK 14inch rims with RE001s. 14x6.5 -25
    Body - Striped, Cusco Safety 21 full rollcage, stitched welded
  3. #93
    Davey & Riki-lee
    South Australia
    Seaford SA
    127.1 in my drift ke lol sliding all over the joint also with stock brakes was.....interesting
    Our introduction - Click here
  4. #94
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Back into the 1:27.3s according to the GPS timer. Before the flywheel went kablammo.
  5. #95
    Josh
    ^^^ oh dear. are u going to be ready for the next race takai?
  6. #96
    Jul 2009
    Vic
    Nup. If i swap everything over onto the spare block ill just be blowing blue smoke everywhere. Not worth it.
  7. #97
    Akio
    Mt Haruna
    Japan
    1:41.6 in the micra
  8. #98
    Jason
    Southern Suburbs
    Default Result from Nov '10
    Engine - MR2 4AGZE bottom end, smallport head, TRD 0.8 gasket, S14 T28bb turbo, 263 8.35mm 20v cam inlet, HKS 264 8.35mm exh, Jap cam wheels.
    Power - 165Kw at the wheels on 13 PSI
    Brakes - F: FC 4 pot w/ Ferodo DS3000, R: Project Mu
    Suspension - F: 480lb coilover, Tokico HTS, whiteline Adj swaybars, 40mm RCA, Cusco camber tops
    R: T3 3 link, super pro bushed top trailing arms, Tokico HTS, 200lb spings, traction brackets, whiteline ajd swaybar
    Diff - 4.3, TRD 2 way T18 (coverted to disc)
    GBox - W55
    Tires & Rims - F:15x8+15 Rays TE37's R888 195/50R15 R: Konig Rewind 15x7+0 R888 205/50R15
    Body - Stripped race car, Full weld in cage to IPRA spec.
    Did 1:21.5700 in the last session. results here:
    EVO IX was quicker but only just.
    Struggled for grip now that the rear end (and entire car) is so stiff. Need to go softer rear spring. HTS front dampers may come out in favour of the TRD yellows but may leave them in.
    Last time I split my dump pipe(not exh gasket as I thought), now I've cooked the dump pipe flange gasket so time for new side pipe off the turbo with bracing. Also looking at ceramic coating the turbine housing to reduce underbonnet temps.
  9. #99
    Senior Member charged's Avatar
    You should come out and race in IP
    IPRA KE25 Corolla S.A #25
    www.sharperto.com.au
  10. #100
    Jason
    Southern Suburbs
    Would like to, and may at some point in the future, but the cost (whilst cheap compared to other forms of racing) is still a little too much for me.
  1. Vic track times
    By doridori in forum Grip and Tarmac Racing Section
    Last Post: 11th May 2018, 07:10 AM
  2. NSW Track Lap times
    By Sprinterboy in forum Grip and Tarmac Racing Section
    Last Post: 24th April 2018, 11:07 AM
  3. On Track Drifting dates and times etc in QLD
    By keiichi in forum Brisbane & QLD Events and Discussion
    Last Post: 18th June 2011, 04:17 PM
  4. SA..s13 track car. gooooooodies
    By sly1 in forum Cars for Sale (Not Toyotas)
    Last Post: 15th October 2010, 06:35 PM
  5. Track only jzx90 294rwkw $8000 SA
    By 4agte70 in forum Cars for Sale (Toyota Only)
    Last Post: 28th April 2010, 10:10 PM
