Page 9 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 81 to 90 of 111
Thread: SA Track Times...well Mallala then!
  1. #81
    Jason
    Southern Suburbs
    Engine - MR2 4AGZE bottom end, smallport head, TRD 0.8 gasket, S14 T28bb turbo
    Power - 120Kw at the wheels
    Brakes - F: FC 4 pot w/ Ferodo DS3000, R: Project Mu
    Suspension - F: 480lb coilover, TRD yellows, whiteline Adj swaybars, Revolver RCA, Cusco camber tops
    R: T3 3 link, super pro bushed top trailing arms, TRD Blue 8 way, 200lb spings, traction brackets, whiteline ajd swaybar
    Diff - 4.3, TRD 2 way T18 (coverted to disc)
    GBox - T50
    Tires & Rims - F:15x7+0 Konig Rewinds R888 195/50R15 R: SSR mesh 15x7.5+7 R888 205/50R15
    Body - stripped road. Cusco half cage
    Was at Mallala today, a little rain in the morning but the rest was good/ideal.
    Bushed top arms in place of rose jointed arms works ALOT better in getting the power down.
    1:22.0500
    Full day's results here:
  2. #82
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    you look to have been the quickest car out there
    Andy
  3. #83
    Jason
    Southern Suburbs
    The GTR was quicker, but couldn't keep it on the track. Looked to be built with big brakes and 300kwish. Was gone by time I got out onto the track.
    The Elfin was good fun. I think I had a few more horse than him and was much better under brakes. He held a little more corner speed, and more linear (NA) power out of the corners was helping.
    I will be staying with 120kw for a while in search of a 1:20 with suspension work.
    Need to go softer rear spring, up the swaybar.
    W box is calling, need to be a little harsher than I have been in the past.
    Really need a set of 4.5's. 2nd out of Esses and Northern just zing's the tyres but 3rd bog's out of Northern and has a bit less pull out of esses.
    One thing I learnt from you Andy at the track day and watching the video's is to attack the curbs alot more. Also now holding more speed into turn 2.
    Can't wait for you to be out there with Beams power.
  4. #84
    Senior Member charged's Avatar
    Did a 1.22.8 today in RACE 4 , still have a issue with the car breaking down at 8000rpm due to a interface error at high RPM, will get it sorted on the dyno soon and chase a few more HP
    A low 1.21 is more than achievable next state round........ Takai and Andy get your arse into gear and come racing with me..... the gutless little 20v is staring to go well
    IPRA KE25 Corolla S.A #25
    www.sharperto.com.au
  5. #85
    Glenn ke_70's Avatar
    Clay
    Barossa!
    whats that other corolla in there? that times incredible he'd have to be running a 3s or somthing
  6. #86
    Thats the nephews Clints Corolla, its runs a 3sgte and his times were a bit off for some reason, it should be around a low 16 high 15 normally
  7. #87
    Jun 2009
    Alex
    Valley View
    Woot! Just broke into the 1:32's in a 20 valve during practise. Could easily do a 1:29 with more aggressive braking (I keep braking too early and coasting for a second).
    Some R888's on the front would help me launch out of the corners better than the toyo T1R's that I have on now. Or I just need to learn to feather the throttle better.
  8. #88
    Andy
    Adelaide Hills
    Managed a 1:22.9 in the final outing in the 4age yesterday, bring on the beams
    Andy
  9. #89
    Josh
    that's a bloody good effort andy..nice work
  10. #90
    Jason
    Southern Suburbs
    R: T3 3 link, super pro bushed top trailing arms, Tokico HTS 48way, 200lb spings, traction brackets, whiteline ajd swaybar
    Diff - 4.3, TRD 2 way T18 (coverted to JDM AE86 disc)
    GBox - T50
    Body - stripped road. Custom half cage
    Rebuilt front end, HTS in the rear (so much better than TRD blue's, you have to try them Frak).
    1:21.300
    Track was a bit shit with drift on the night before with dirt all over the track.
    Was mostly dry except the last session where the track was drying out, turning Pacific into quite the handful. 2nd was instant wheelspin, 3rd was only slightly better.
    Had some boost cut issues in practice with the cold air at about 1.2bar in the top of forth just before the braking point into the esses.
    With 4deg camber on the front it walks a bit through the kink but its best to just hang and let the tail slide a bit. Funny when you look at the speedo comming out of the kink and its just points at kmh.
    Negative's: Front rotor's are done. Blown exh manifold gasket (tiny bit) or (less likely) the turbo gasket.
    Work for next time: HTS for the front. Put some more power into it, I think cams alone will be over 140rwkw and fix my boost creep issues. Move oil cooler/adjust ducting (oil in sump over 120deg after 3-4 HARD laps but as soon I back off back below 110 pretty quick. Max was 125deg.).
    W55 and new clutch.
    Proper CAGE.
  1. Vic track times
    By doridori in forum Grip and Tarmac Racing Section
    Last Post: 11th May 2018, 07:10 AM
  2. NSW Track Lap times
    By Sprinterboy in forum Grip and Tarmac Racing Section
    Last Post: 24th April 2018, 11:07 AM
  3. On Track Drifting dates and times etc in QLD
    By keiichi in forum Brisbane & QLD Events and Discussion
    Last Post: 18th June 2011, 04:17 PM
  4. SA..s13 track car. gooooooodies
    By sly1 in forum Cars for Sale (Not Toyotas)
    Last Post: 15th October 2010, 06:35 PM
  5. Track only jzx90 294rwkw $8000 SA
    By 4agte70 in forum Cars for Sale (Toyota Only)
    Last Post: 28th April 2010, 10:10 PM
