i thought kyb didnt make short stroke shocks for ae86? (manufacturer specification)
if you want something legal you have to stay within manufacturers specifications. but cutting the springs and using shox from a different car is more illegal.
you can get short stroke excel g kyb's and springs to suit from AJPS if your unsure... otherwise i reccomend falcon springs (requires cutting) with sierras pedders sports ryders.
ok fair enough i never thought about it like that.
will the AJPS gear, suit what im after? drift ready rear end? not to soft? descent ride height?
im not neceesarily after the cheapest combo, rather a good combo that works and has been prooven, but the falcon spring sierra shock combo looks attractive...
ajps 6kg springs are good...
even if you dont upgrade the shock straight away its still an improvment...
but you mos well buy shocks and leave it at that
Springs determine ride hide, shocks control the bump and rebound of the springs
cheers kane!
send us and email and i can show ride height pics
yeah i realise that, but obviosuly you have to have your car at a certain height in order to use these short stroke shocks
- Blaise Pascal
what rate are ford falcon au springs after being cut? any ideas?
cut at the height most people normally run, between 5 -6 kg/mm
ok so these would be stiffer than cut kings at the same height?
