Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 36
Thread: Recomendations
  1. #21
    Veteran driftke70's Avatar
    Ryan
    Buderim
    intruiging
    wheelfriends.wordpress.com
  2. #22
    some good recommendations popping up in here
    keep it up
  3. #23
    Ferny Grove
    wow
    lets not do drug talk here
    post deleted
  4. #24
    aaron_drift
    > Drum and Bass techno
    > Coffee
    > Cigarettes (plenty of)
    > Emry cloth (its like sandpaper but better!!)
    > Grinder (turn s series brakes into t 18)
    > Gasket Goo, this stuff does everything buy the red type from supercheap.
  5. #25
    Veteran DRFTPG's Avatar
    ADAM
    socket set, ratchet spanners, zip ties and duct tape
  6. #26
    Kevin
    Constitution Hill
    A set of good side cutters to do all your electrical work...... and most important......... cut your cable ties
  7. #27
    Oldschool Member
    Aug 2005
    Oakleigh
    old cap or a bandana. not easy to wash shit off ur hair
  8. #28
    Oldschool Member
    Mar 2007
    Magnetic trays??
    Just keep the lids off those empty spray cans and such that you throw away.
    Perfect small part holders.
  9. #29
    Veteran johl's Avatar
    Johl
    two words- "death mallet". i dont care how much wd40 u wanna waste tryin to get that bolt loose or whatever.... just smash shit wit a death mallet and it'l happen for u... be sure to get the heaviest mallet u can find as it will hit everything alot harder... therefor increasing the "death mallets" fatalities....
    ps. i can not be held accountable for any injuries/more damage u cause whilst wielding ur own death mallet... u'v been warned
    -johl
  10. #30
    Jonathan
    My advice: only buy a house with a flat paved driveway. Do not use your emergency jack when on cobble stones.
    And in the garage, replace the single globe light with 100 fluro tubes. Make it bright like inside Woolsworth. If you are having the garage built, get the floor "pool finnished" smooth flat like at gas stations. Then paint the floor with the stuff they used at your local Toyota dealership.
    Get a 20 litre drum of brake cleaner. And a wurth squirter bottle thing. Be like a real mechanic and make grease disapear with a squirt.
    Don't stuff around. You NEED a solid bench, and the biggest bench vice you can afford. Do not make the bench top from a hollow house door.
  1. Diff oil recomendations?
    By stefan in forum Technical - Questions
    Last Post: 15th October 2010, 10:06 AM
  2. Engine reconditioning, costs recomendations?
    By JinxD in forum Adelaide & SA Events and Discussion
    Last Post: 25th July 2009, 05:25 PM
