Results 1 to 5 of 5
Thread: brake fluid loss
    Stefan
    Parkinson
    hi im going through alot of brake fluid lately ive put a genuine toyota master cylinder in and ive checked lines thourougly and no leaks i got new drum pistons in but still leaking
    what is this problem?
    Rob
    Moorabbin
    it must be going somewhere, just systematically go through your whole hydraulic system and look for leaks. Likely culprits are cylinder seals, connectors and flexible lines.
    Get the car up and get someone to apply pressure to the brakes and go under and start feeling around for wetness (lol)
    Stefan
    Parkinson
    kool ill check it on weeknd ive got a feeling its the rear drum lines
    they has a bit of wetness last time i checked but it may have just progressivly gotten worse
    Jun 2009
    Michael
    Check the rear wheel cylinders also.
    Stefan
    Parkinson
    there brand new wheel cylinders at rear so its the rubber lines from what i can see so far
  1. An insight into Brake Fluid
    Last Post: 28th August 2012, 06:55 PM
  2. loss of brake pedal after drift
    By Bozu in forum Technical - Questions
    Last Post: 16th August 2011, 11:49 PM
  3. Fluid in brake booster?
    By ae86 slide in forum Technical - Questions
    Last Post: 12th October 2010, 09:54 PM
  4. leaking brake fluid ?
    By sun_moon in forum Technical - Questions
    Last Post: 5th April 2010, 06:51 PM
  5. Which oil/brake fluid
    By willa in forum Technical - Questions
    Last Post: 30th October 2009, 11:01 AM
