Results 1 to 10 of 12
Thread: after market computers?
    Oldschool Member
    Mar 2006
    ok im buildin my AE86 4AGTE (<--- YEEERRR BOOIIII cant wait) but just wanted to know wot kinda computers have most people found to be good i was just thinkin bout something like a microtech but thought someone else might have a bit more info on the subject, plus im from geelong so i want to kinda find a good tuner aswell thats close by and i do know a good microtech tuner close by
    (DALTON AUTOMOTIVE) but im up for any suggestions
    thanx for any help givin
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    microtech LT10s man i have heard really good things about theese so much i have just perchased 1 last week... yet to wire it up n see how it goes....86sp also has 1 of theese on his 4agte and he has nothing but good things to say bout it.... so IMO get a LT10s
    note: mine will be running 20v ill let you know how it goes
    MY JZX83 (clicky)
    Jun 2009
    Michael
    Yeah im using one on mine. Wiring was easy and most places can tune them. Had my first issue just the other week with it.. It decided to clear all the maps and left me stranded. But other than that its good value for money.
    Mar 2010
    Dave
    Just a quickie, anybody use the power fc ap or djetro?
    Jonathan
    MicroTech is fine. Either second hand LT8S or the new LT10s.
    If you are realy interested in data logging and having lots of outputs for some reason, you may want to look at something else. MicroTech will not do: knock sensor, closed loop, autoTune, 3D ignition display. I am not sure if it can do idle speed control, not sure.
    MicroTech can do: 3D fuel maps, data logging, O2 display, thermo fan, rev limit, boost cut.
    Elite rthy's Avatar
    Leo
    Tulla
    i will be using a wolf 3d
    Bill
    Gold Coast
    Check out the Adaptronic, they're much better than any of the Microtechs and cheaper.
    Oldschool Member
    Jul 2006
    There is a whole lot to be gained in a turbo application via a good tuner. These tuners are few and far between, but if you find one, remember the name.
    When I went looking for an aftermarket ecu for my 4AGE, I checked all the above and some more out. In the end, I got the best. I figured that it was better to spend the money now than to buy something else, then have to sell it to buy the best in the end anyway.
    Now that it is all set up in the car and I've had it running for a bit, I would thoroughly recommend getting Motec. Its a lot cheaper than you think, and it has all the functions you could want. If its going to be a street - driven car, its the only way to go.
    Leo
    Jonathan
    I heard the head designer for MoTeC left and started Autronic, but Motec still has better marketing so is considered as "the best". Thats all I know.
    But for a young guy who just wants to get something running and will change the setup within a year anyway, I don't think its cost effective to spend more than $2000 on a ECU and as much again getting someone to tune it with closed loop, perfect cold start etc. Most will be happy with a quick tune on the dyno, and can live with having to warm the car up if need be, and a high idle. There is no reason why a MicroTech can't run a nice daily driven car. But if the engine is modifyed with cams, idle will be about 1000rpm, not 600rpm. But it can still be turn key and go from cold.
    What extra functions of the MoTeC did you end up using?
    I would consider a high end ECU if making a prototype vehicle with low emissions or duel fuel. Or a competitive race car where 2% more power and less fuel per lap ment something. But then you need to know how to work it...
    Justin
    hronsby
    I use a MoTec on my car but being a dedicated track car you use what is available both for reliability or access of people with knowledge if you have a problem. I have heard alot of people talk quite highly of the microtech and they should do the job fine, many people also use the EMS which arent a bad unit, alot of off roaders use these as they are pretty reliable. I suppose the best ECU is like anything, fits the budget, has the functions needed to run the type of engine you have.
  1. Replies: 9
    Last Post: 3rd January 2010, 12:20 AM
  2. after market tacho
    By #109 in forum Technical - Questions
    Last Post: 11th August 2008, 08:41 PM
  3. after market seats
    By Selk in forum Technical - Questions
    Last Post: 15th January 2006, 12:07 AM
