Results 1 to 4 of 4
Thread: clutch question
    Adan
    Oxley Park
    The clutch in my ae71 wagon is just abou dead. Im tossing up the idea of changing it myself to save a bit of money and to get the experience doing it.
    Does anyone have any special hints or tips for doing it? i think the basic idea of take gearbox off, take of clutch assembly, and then put back together should be pretty straightforward, but i wouldnt know of little things to look for, any tips would be great.
    Also, im getting a fwd bigport motor which still has a heavy duty clutch and lightened flywheel attached to it. Would these fit onto my 4ac? Because it would save me buying a different clutch kit then.
    thanks
    adan
    Elite rthy's Avatar
    Leo
    Tulla
    there are various tips for removal of the gearbox, just do a search for it or try here:
    I drop the rear mount and use a 1m extension myself
    the clutch can be swapped
    Senior Member ToySprinta's Avatar
    Steve
    Padstow
    The 4ac and 4ag flywheels are different.
    4ac = 6 bolts
    4ag = 8 bolts
    Adan
    Oxley Park
    oh okay thanks for that.
    i didnt think of looking on rollaclub for some reason, they seem to have everything on there.
    if the clutch can be swapped onto the stock 4ac flywheel then thats good, i just wasnt sure on the sizes seeing everything is different and theres no simple table which tells you the size in the different variants.
    yay for 50 dollar bluetop with clutch still attached
  1. 212mm clutch question
    By trikzlane in forum Technical - Questions
    Last Post: 1st August 2011, 02:20 AM
  2. another clutch question
    By pieman18 in forum Technical - Questions
    Last Post: 21st August 2010, 06:41 PM
  3. Quick clutch question and spigot question
    By wideslider in forum Technical - Questions
    Last Post: 9th August 2008, 12:45 AM
  4. clutch question
    By muldog86 in forum Technical - Questions
    Last Post: 3rd January 2008, 10:03 PM
  5. Clutch question
    By unit101 in forum Technical - Questions
    Last Post: 24th May 2007, 03:14 PM
